motor stand ?
Discussion in 'The Hokey Ass Message Board' started by 46chevypanel, Aug 2, 2008.
  1. 46chevypanel
    46chevypanel
    from york,pa
    i know this is a dumb question but what bolts do i need and how many washers do i need to bolt my 283 to my enginge stand. thanks for the input
  2. TheMonkey
    TheMonkey
    from MN
    is this stuff not in front of you so you can't measure it... or you are not sure how to measure for these?
    either way, might be difficult for anyone to answer without knowing what kind of engine stand you have.
    basic engine stand that mounts where bellhousing bolts up should be ordinary 3/8" - 16 thread per inch.
    how many washers? only reason you'd need more than one per bolt is if your bolts are bottoming out when threaded in.
    is this what you are axsking?
  3. use good quality bolts and washers.
    and make sure they thread most of the way into your block.
  4. jimmyv
    jimmyv
    Not too hard to bolt an engine up to a stand.
  5. Tony
    Tony
    I'll bet that helped him figure out his answer.....
    I use grade 8 bolt's, although it's overkill..the hole's are 3/8 16 thread on your 283 as The Monkey said.
    The length will depend on your stand. Ideally you want a good 3/4" of thread showing with the bolt through your stand..This way you have that 3/4 in the motor..
    Washer's..I just use a couple on each bolt..Nothing special.
    As was mentioned, IF one bottom's out, you can add washers to "shorten" the bolt until it clears and still has sufficient depth into the motor.
  6. 46chevypanel
    46chevypanel
    from york,pa
    thanks for the reply's and yeah i know it ain't hard to bolt up a motor to a stand but when you ain't ****ed with any of this stuff for years you sorta forget things, sorry were not all as good as you jimmyv
