can somebody tell me what type of relay this is?
Discussion in 'The Hokey Ass Message Board' started by Hawaiian Punch, Aug 5, 2008.
  1. Hawaiian Punch
    Hawaiian Punch
    I need to change it and of course its not the original one.
  2. OshkoshRob
    OshkoshRob
    from Oshkosh
    Looks like a voltage regulator.
  3. wetatt4u
    wetatt4u
    CORRECT! Voltage reg.
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    3rd vote for voltage regulator..usually they have a cover on them
  5. Hawaiian Punch
    Hawaiian Punch
    ok mahalo for the help.
    By the way I took the cover off so you could see the inside and be able to reconize it much easier.
    How much these things run about?
  6. plymouth1952
    plymouth1952
    there cheap just remember to polerize it before you use it
  7. 51 Leadsled
    51 Leadsled
    from NC
    What if he is not polish?
  8. Hawaiian Punch
    Hawaiian Punch
    what the heck is that? lol!! sorry my friend, I never heard of Polerize before, what and how can this be done? Mahalo for the help.
  9. Hawaiian Punch
    Hawaiian Punch
    LMAO!! I'm far from it.....well I do have a small bit of German some where down the line. lol
    eh I was wondering, what cl*** would my car be in? I mean like your car is considered a lead sled right, what would my year of car be considered?
  10. Bruce Lancaster
    Bruce Lancaster
    OK...you don't know what it is. How do you know that it needs to be replaced? This would seem to need some ****ysis before the credit card or the screwdriver come out.
    Type of car needs to be known before it can be polarized, too, if it does need fixing...
  11. Hawaiian Punch
    Hawaiian Punch
    its a 1957 Lincoln Premiere with a 368 Lincoln motor. I took it to the shop a little bit ago and told him about the new battery put in a couple of weeks ago and the generator being rebuilt this past Nov. he tested the system and said that it seems to be the voltage regulator, the reason I posted up the pics was because I didnt know which one I should be getting and I was hoping that somebody on here would reconize the type and send me towards the right direction.
    The gen light would come on sometimes, sometimes mostly at night but lately during the day time, and sometimes with the aircon on and thats on top of being on the freeway with the rpm's up high where it should be high enough to charge up the system, then all of a sudden the light would go off.
    my battery would drain sometimes which happened to me twice and left me stranded because the car would shut off when comeing to a stop.
  12. Andy
    Andy
    I would clean the contacts and see what happens. They get a film on them and don't work. That's all I did. A parts store should fix you up if required. Another trick is to disconnect the battery while running. Stops= generator. Runs= reg. Don't let it run more than a moment. Just see what happens
  13. Hawaiian Punch
    Hawaiian Punch
    Kool! mahalo for the tip!
    I'll try that right now, be right back in a few to let you know what happens.
  14. Mr. Creosote
    Mr. Creosote
    To polerize dont you jump th F terminal (field) to the + terminal (battery)?
  15. Hawaiian Punch
    Hawaiian Punch
    K Andy I guess its my genarator, it stops running once I disconect my battery.
  16. JohnEvans
    JohnEvans
    from Phoenix AZ
    You need to have it running about a 1000 RPM when pulling the cable to test for generator working with everything else turned off.
  17. Tighten your belt until you cant turn the pulley by hand
  18. 383man
    383man
    from Md
    You polerize the generator not the regulator. Ron
  19. 5window
    5window
    Generators can run negative or positive ground systems and, therefore, need to be polarized to run a certain way given your system. Here's a good place to get started:
    http://www.nls.net/mp/volks/htm/gen.htm
    Google "polarizing a generator" for a lot more information.
  20. jimmyv
    jimmyv
    The generator gets polarized not the regulator. You can usually adjust the regulator and clean the contacts to get it working correctly.
  21. Hawaiian Punch
    Hawaiian Punch
    oh shoot! ok I'll try that one in the morning then.
    Mahalo for all the much appriciated help gang.
  22. lewislynn
    lewislynn
    **** can the generator and regulator. Replace it with an internal regulated alternator.
  23. Hawaiian Punch
    Hawaiian Punch
    fabrications might be a pain yea?
