Why Y-Block!!!!
Discussion in 'The Hokey Ass Message Board' started by NORCALCUERVO, Mar 20, 2008.
  1. Sam_Fear
    Sam_Fear
    Rams horn dual manifolds were used on the Lincoln motors in BIG trucks. You can often find a pair on e-bay. They look identical to the Ford manifolds, except the outer two bolt holes are not inline with the rest. The Ford rams horns, of course, have the bolt holes in the same plane. The Lincolns usually go for cheap compared to the Fords. The Fords are now repoped now too - for $$$!
  2. Clark
    Clark
    I was told the easy way to tell the Lincoln rams horn from the Y block rams horn is the Lincoln's have a gusset on the top center of the manifold.
    Clark
  3. DirtyTace
    DirtyTace
    Here's mine. Crane electronic ignition conversion, 4bbl manifold, 600 cfm Edelbrock carb. I've since installed a set of Red's Headers. Nice thick flanges - sounds pretty mean through the open headers. The truck's not completed yet so I haven't test drove it yet.
  4. Dominick Hide
    Dominick Hide
    Picture has been posted before, but in case you missed it...
    McCulloch supercharger, Stromberg carbs, Fenton intake, Du-coil ignition, Thomas magnesium rockers and Hedman headers. 1957 Ford Courier
  5. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Y blocks are beautiful motors, great sound that IMO rivals that of a flathead. My ex had a a 61 fullsize w/ a 292 in it. She sent it out for a rebuild ($$$$$$$) but when it came back it was in the ballpark of 290 ponies and it MOVED! I was surprised!
  6. NORCALCUERVO
    NORCALCUERVO
    Nice!
  7. NORCALCUERVO
    NORCALCUERVO
    Cheap? not really hahaha wich ones did you get?
  8. Fidget
    Fidget
    Are those Ford emblem valve covers? If so, did you make those yourself or were they available back then?
  9. Sam_Fear
    Sam_Fear
    Any truck 292 had the raised letter FORD valve covers. Mines got 'em. He just painted the letters all nice - look good.
  10. MP&C
    MP&C
  11. Hollow Head
    Hollow Head
    from Finland
    I also have became as a Y-blocker. Hell, why not. So far I've done a 292 with twin turbo set up and currently working on a single turbo 8-point fuel injection Y-block.
  12. I just put dual straights on the 292 in my '61 Mercury, it really woke it up, and it's the best sounding motor I've ever had with straights. It had single exhaust factory, but no crossover, not sure when they started that. My '61 pickup has a crossover.
  13. Greasy71
    Greasy71
    from SoCal
    I have a 55 Customline with the 272. Is there anyone in the SoCal area who would not mind showing me the ropes with these motors? Mine is currently running but leaks like a stuck pig, and I have already replaced the rear main with the rubber one and it still leaks. i want to learn to turn wrenches on this thing, but need a mentor.
    Thanks
  14. yblock292
    yblock292
    Agree with crashnburn, my 292 bored .030 4 94's and straight pipes in my Model A , love the sound !
  15. candyman
    candyman
    My '61 fairlane has a 312 in it. I cut off the single pipe and drove it down to the muffler shop and had dual pipes fitted up. I had no hood on it t the time as the motor had just been put in. You wouldn't believe the looks and hollers I got driving it home. Those dual pipes with gl*** packs just rapped.Y-blocks are cool. They are a bit difficult to get parts for though. At least compared to a sbc or even a flathead for that matter.
  16. RichFox
    RichFox
    What you guys don't aperciate is that Y blocks are good to use for more than just Y blocks. Did you know the head is a near bolt on for '29 - 32 Plymouth four bangers? And I'm not the only guy to have done it. Somebody had to tell me.
  17. GothboY
    GothboY
    from SoCal
    I just run mine stock. It had been sitting since 78 when I got it in the ninties, fired right up, and has been running great ever since. Why mess with a good thing. Maybe if it breaks, I'll hop it up. It's all original factory. It's got more than enuf oomph for my 56 ford delivery. Single exhaust, soI just cruise it. It's good up till 55mph, then the factory 4.29 gears keep me in check...
    -GothY-
  18. jimmyv
    jimmyv
    Putting this 292 in my 31 coupe
      31.5 KB
  19. John O
    John O
    from Central NJ
    No ****, now that's interesting! I've run 2 Y's in my 54' Merc. The original 256 Merc engine (a bored 239) and I'm presently running a 62' block with 56' heads and an Edelbrock w/trip 94s. They are without a doubt the best sounding engine I've ever heard!
  20. Mooseandsqurl53
    Mooseandsqurl53
    from N.J.
    Good luck trying to kill one of those engines. I had one in my '56 P/U and I was anything but nice to it. It never gave me a bit of trouble. Those engines might outlive us all. As mentioned before, just keep the oil clean.
  21. candyman
    candyman
    I smoked 3 of em in a year!
  22. John Mummert's www.ford-y-block.com website is THE resource for Y-Blocks, hands down. Ted Eaton www.eatonbalancing.com is also a Y-guru and hell of an engine builder.
    Here's my C2AE 292 Y-Block in my Model T with an Edmund's 3x2 Intake & Stromberg 97's...
