64 1/2 Galaxie Light Issues
Discussion in 'The Hokey Ass Message Board' started by THX_138, Aug 13, 2008.
  1. THX_138
    THX_138
    Anyone who could help me out with this I would GREATLY
    appreciate it.
    Have a 64 1/2 Galaxie 500 XL, Having problems with brake
    lights, directionals. The car also has the slide-a-side steering
    column.
    The entire car seems to be untouched wiring-wise except for
    big feet getting hooked up in the wiring under the dash a few
    times maybe.
    Where the run of wires comes down the steering column they
    all have spade connectors that seperately insert into two seperate
    plastic plugs. Eight wires. Actually only seven, one is the horn
    and is correctly hooked up.
    Five of the eight wires match color In&Out of the connector,
    but do NOT function anything when connected matched up. I've
    had them so many different ways, but obviously NOT found
    the right combination yet.
    Does anyone have a wiring schematic of this particular
    connection area or a link to one? I have checked ALL
    connections and power tested them directly at the light.
    Checked each wire for continuity and any possible bare spots.
    I'm not a total moron and usually have no problems with wiring,
    but I'm outta luck with this one.
    A quick description or wiring diagram would be awesome if
    someone has the know how.
    Thanks in advance.....
  2. lgh1157
    lgh1157
  3. THX_138
    THX_138
    Thank you for those two links but I've already been to them.
    They are however the only ones I could find at all.
    On the bottom link "left page" the area behind the
    "direction signal switch"
    is where my issues are.
    Those two white blocks on the
    schematic. With 3 wires across each plug and one atop each.
    One being "L" shaped and one being "T" shaped.
    So placement of wires according to the schematic
    is kinda not possible, unless I just am missing something.
    The schematic in the link just shows them as flat and also
    does not show the color of the wires coming out that run
    up the column to the switch. they are different then what
    runs into it.
    Oh.... I checked all the grounds too...was the very first thing I did
  4. I do not have a schematic for you right now, but I have a tool which is called a Power Probe. (yeah yeah for the pervs)
    basically it hooks to a battery, and it gives 12 volts to whatever wire you touch it to. It has a safety breaker in case of a short.
    So you give 12v at one end, and you can trace it through the harness until you get voltage.
    It comes in handy, most tool trucks have them, and I'm sure by now they are readily available online.
  5. THX_138
    THX_138
    Pretty much already done the same thing with a straight wire to
    the battery, but it's inneffective because for everything to work
    properly it seems they must ALL be hooked up.
    (except for the horn) As some things feed back
    through the directional switch itself I think.
    About ready to just buy an external column directional box and
    wire the brake lights direct.....:eek:
