S 10 rear end help
Discussion in 'The Hokey Ass Message Board' started by bolsa boy, Aug 14, 2008.
  1. bolsa boy
    bolsa boy
    I'm running a S10 Two wheel drive rear end on my Roadster. The guy I got it from didn't remember what year it was other than late 80's. Now I need to get the driveline for it. What years should I be looking for.
  2. Ole Pork
    Ole Pork
    As far as I know , the 2wd's used a 2pc driveshaft. I have one in my garage. I also have a 4wd rear end for my Chev. I couldn't tell you if they are the same, as I didn't take that one out. Your best bet is to measure the universal saddle and check accordingly.......
  3. Snarl
    Snarl
    I believe it was just the Long wheelbase that was 2 pc.
    A Blazer or shorty truck should work, ***uming they are long enough for your application. I'm not sure it makes any difference as to 2 or 4WD, or the years. But measure the width of your rearend yoke, and compare before pulling it out.
    Any salvage yard worth a dam would be able to look up in a Hollander interchange manual and tell you what your options are...
  4. the machine
    the machine
    check your wheel base. 118" reg cab long bed, 125" extended cab, i think 112" reg cab short bed, blazers were shorted than that. Check with abomination he knows all about it.
  5. the machine
    the machine
