Bellhousing Question.
Discussion in 'The Hokey Ass Message Board' started by timmy t, Aug 14, 2008.
  1. timmy t
    timmy t
    A friend of mine loaned me an alum. chevy bellhousing for my duece sedan project.(if it works Ill pay him for it) My question is what the bellhousing came out of, He said a nova. The clutch fork angles down at about 45 degree angle instead of strait out the side.If it is a nova what year?
  2. squirrel
    that would be the early novas, 62 thru 1967. In 1968 they turned into normal cars.
  3. btmatt
    btmatt
    I believe that I saw them in V8 monzas from the '70s also
  4. valkokir
    valkokir
    from DeKalb, IL
    yes, except monza's had an oddball fork setup that were a cable pull instead of a push setup. I believe a search for Monza bellhousing will turn up a pic I posted of one. I suspect if it was one of these you'd have noticed as a standard fork will not work.
  5. squirrel
    82-83 camaros also had the fork at an angle, but not 45 degrees. They used normal Z bar mechanical linkage.
