fender skirts. tips?
Discussion in 'The Hokey Ass Message Board' started by lowgobuick56, Jul 19, 2008.
  1. any good tips on making fender skirts?
  2. Any pics of what you are trying to build them for?
  3. Fifty5C-Gas
    Fifty5C-Gas
    yes, dont make em, skirts are for girls not cars...
  4. they are going on a 56 buick century wagon. but i dont know how to post pics yet im pretty retarted with computers.
  5. greenhell56
    greenhell56
    from york ,pa
    i have aftermarket ones that i think are for a 55 and i have a 56 luckly
    i diddn't pay **** for them a friend agve them to me BUT if they make the 55 they might make the 56 fox craft or fox fire i think their called
  6. chopper99
    chopper99
  7. brewsir
    brewsir
    make a cardboard template to get the right size and shape....then go cut a roof off a car at the junkyard and split it down the middle...use one side on each side of the car so you have matching compound curves. On earlier cars...like 30's-40;s cars a VW bug roof works great. Make a framework out of steel and figure it out !
  8. bct
    bct
    i'd say thats a good tip
  9. Ian Berky
    Ian Berky
    wow!!
  10. skidsteer
    skidsteer
    Will be easier to find a used pair, but if you want to see what's involved in making your own, find a copy of the April 2006 issue of Rod and Custom. Good article on how to form and brace them, however nothing in the article on attaching them to the car...........?
  11. brewsir
    brewsir
    Get a little creative on attaching them...a couple of steel strap "tabs" to hold the top edge tight and copy a real set for the bottom hooks...pretty simple really.
  12. bct
    bct
    also check the tech section...good article there
  13. cleatus
    cleatus
    from Sacramento
    Yeah man, just radius the quarters and make it a g***er - those things are RAD - wooooo!
  14. wow thanks for the tips, helped a lot.
  15. Squablow
    Squablow
    The flat part and the part that will follow the opening of the wheel should be easy enough to make using templates. For the lip at the bottom (***uming you want flush-fitting skirts) you can cut a straight section of a front fender opening out and weld it to the bottom.
    Look at some eBay auctions of fender skirts and collect pictures of the back sides of the skirts to give you some mounting ideas. Foxcraft skirts usually have a simple clamp in the center and little tabs on each end, would be easy enough to make.
  16. Fifty5C-Gas
    Fifty5C-Gas
    wow, this is a "RAD" g***er, huh??????
  17. fivepointink
    fivepointink
