Hydraulic clutch set up. Advice please.
Discussion in 'The Hokey Ass Message Board' started by Paul Y, Aug 20, 2008.
  1. Paul Y
    Paul Y
    I am going to install a manual box into my 56 PU and think the easiest way to do this is by the use of a hydraulic set up.
    Car has a Camaro subframe, not sure if that makes any differance or not to be honest but it has.
    I have the manual pedal box out of a Camaro, at presant the PU has fitted a auto pedal box out of a Camaro.
    The gearbox is a T10.
    So my question is, what components do I need and has anyone done a swap like this and can provide some pointers?
    Or.... Would it be easier to use a cable set up like that from a Mk4 cortina?
    Any help or advice greatfully received.
    P.[​IMG]
    <!-- / message --><!-- sig -->
  2. blackout
    blackout
    What bellhousing do you have?
  3. Paul Y
    Paul Y
    Standard Aluminium one, no provision for a slave cylinder as it stands at the moment.
    P.
  4. blackout
    blackout
    I have built a bracket, attached to the engine block to support an external slave. Do you have a master for the clutch? Determine the diameter of the clutch master piston. You will be paying some attention to the relationship of the diameters of the clutch and slave for pedal effort. You want about 1" travel in the slave.
  5. Paul Y
    Paul Y
    I have none of the hydraulic components at the moment as I noted from research that they have to be matched, just was not sure what that match had to be.
    Any pointers on the components you used and dimensions for the bracket you built?
    Thanks
    P.
  6. blackout
    blackout
    The bracket is triangulated. Mounts to the threaded boss in the block that was used for the Z-bar pivot ball and the bellhousing hole. Then your pushrod lines up with the clutch fork. Speedway sells a 7/8" diameter push slave that works well. It has 2 mounting tabs for 3/8" bolts, make a pushrod from a hardend 3/8" bolt.
    The relationship of master diameter to slave diameter...a larger master creates more pressure with less travel, easier pedal...a smaller master creates less pressure with more travel and harder pedal. Disclaimer I may not be correct on these cylinder relationships, experts please confirm/correct.
  7. MFP2241
    MFP2241
  8. Lee Martin
    Lee Martin
    Are you talking about a slave cylinder and fork combination or are you going with a hydraulic throwout bearing?
    -Lee
    Atomic Radio
    www.atomicpinup.com
  9. fab32
    fab32
    The relationship of master diameter to slave diameter...a larger master creates more pressure with less travel, easier pedal...a smaller master creates less pressure with more travel and harder pedal. Disclaimer I may not be correct on these cylinder relationships, experts please confirm/correct.[/quote]
    You have the relationship reversed.
    The larger master will create less pressure but more travel. The smaller master will create more pressure and less travel.
    Frank
  10. Paul Y
    Paul Y
    I do not want to use a hydraulic throw out bearing, I want to use a slave cylinder and clutch fork set up.
    As for the relationship of the cylinders to each other what would be the recomendation for either?
    Getting a bit confused....
    (not that difficult really....)
    P.:D
  11. blackout
    blackout
    I used a 1 1/8" dia. master, and a 1" slave that has 1.25" travel. I have also used a 7/8ths slave with the 1 1/8" master on other cars. The pedal is kind of stiff on those combinations, but the pedals themselves are cut down and altered. You will have room for full length pedals in the truck, so the adittional leverage will make it easier to depress the pedal.
    I have another car with a 15/16ths master, with a 1" slave. Stock pedal. The pedal is effortless to depress.
  12. fab32
    fab32
    I have another car with a 15/16ths master, with a 1" slave. Stock pedal. The pedal is effortless to depress.[/quote]
    You've just proved what I stated in my above post. When properly proportioned a hydraulic setup is effortless and very effective. Just eliminating the h***le of getting the mechanical system to work makes them worthwhile.
    Frank
  13. Paul Y
    Paul Y
    Thanks for the information, as my wife wants to drive the PU and she cant drive an Auto I will go for the effortless option!
    Could you tell me what the master and slave came from for this option or where you purchased them?
    Thanks again,
    P.
  14. blackout
    blackout
    Master is Tilton. Slave is C-4 Corvette.
  15. Paul Y
    Paul Y
    Thank you Sir!
    The HAMB comes to the rescue once again.
    Owe you a beer if you are ever in London.
    P.
  16. Paul Y
    Paul Y
    That looks very nice and neat.
    I was considering using the clutch cable from a Ford Cortina (small family car of the mid 80's) but could not figure out in my head how to do it.
    Looks like you have just answered that question!
    Thanks
    P.
  17. Snarl
    Snarl
    Why can't you use the stock '56 pedal setup?? the fork angle should be the same, and the overall position of the fork end should be near the stock location, even with the subframing??
    ***uming the pedal ***embly is going to stay under the floor...
  18. RichardW
    RichardW
    I am using the Wilwood master and slave cylinder on a sbc. It has worked great for almost 50K miles. It is a pull cylinder that is attached to a stock fork.
  19. Good Wood
    Good Wood
    from pa
    There's a good article in the November Rod & Custom about fabbing a hydraulic system.
  20. Drive Em
    Drive Em
    That is a circle track style bearing that will not work on a 10 or 10 1/2" clutch. You will need the Howe throw out bearing.
  21. 55 dude
    55 dude
    the guys over at pirate 4x4 build some pretty neat setups check them out.
  22. JohnEvans
    JohnEvans
    from Phoenix AZ
    My T has 1&1/8 MC and a 1&1/16 slave both stock Chevy PU sizes. 10.4 crown HD diaphram clutch. Wonderful progressive feel and about a medium effort. Slicker 'en snake snot !
  23. Paul Y
    Paul Y
    A quick update.
    After trawling the web I came across this great explanation of the ratio between master cylinder and slave cylinder and the effects changing one has on the other.
    Hydraulic Multiplication:
    The ratio of the piston sizes (in&#178;) Slave:Master is what determines the mechanical advantage (softness of pedal) in the system. So that if you have a &#189;" master and a 1" slave, 10lbs of force on the master piston will produce 40lbs of force in the slave. (It is a ratio of the squares of the radii: sr&#178;/mr&#178; = .5&#178;/.25&#178; = 4)
    Volume (in&#178;*in) of fluid moved will determine the throw and is the inverse of the above ratio. So in the scenario above, 2" of piston travel in the master will produce .5" of travel in the slave.
    So. Now all I have to work out is what it the distance required to fully disengage the clutch on a SBC with a T10.
    Anybody know what this distance is as I do not have all the parts to do my swap over yet and would like to have them all here before I start as the PU is rapidly becoming my daily driver.
    P.
  24. JohnEvans
    JohnEvans
    from Phoenix AZ
    My dogs can't push the clutch pedal down while I lay a ruler on the travel of the release arm, but going by my setup I would say at least 1 inch. I have found over the years of pushing parts and using hyd clutch release systems, most have very near equal M/C and slave cylinder bores. So what ever size M/C you are using go for a very close sized slave. As long as both bores are near equal pedal effort will not change no matter if both bores in each set are 3/4 or 1&1/4, as you are not changing the ratio between master and slave.
  25. fstfish66
    fstfish66
    from eastern pa
    i am currently in the middle of converting from a tilton hyd bearing to a fork and puller slave cyl,,i am having trouble getting the slave to travel more the 7/8 of an inch,,all tho this may be enough to disengauge the pressure plate,,ide like a ful inch of travel
    im using a CNC puller slave i bought at speed way and a 3/4 bore master with i 3/32 stroke,,,
    after talking to CNC finally they are telling me i need a master with 1 1/2 inch of travel,,there slave has 1 1/8 total travel,speed way was advertiseong it at ALMOST 1 1/2 inch of travel,, till i got them involved in all this,,,neither company CNC the maker of the slave or speed way has complete info on this,, and no instructions or specs with the slave,
    so speed way is going to ship me a master, but wont charge me shipping or charge me for the _ an fittings,,see how it works out :cool:
  26. I'm using this on my F100, with a 12" '60-'72 chevy truck aluminum bellhousing
    (GM#: 6263756):
    http://www.novak-adapt.com/catalog/kit_hcrc.htm
    You don't have to use all their parts- rockauto.com has just everything else very reasonable.
    But by the time you make the pattern for the bracket and pay someone to laser cut it, you could pay for the entire matched kit from Novak.
  27. Scott
    Scott
    I am using that setup. I kind of cobbled it together. It would be much easier to by the whole setup from one place after you figure all the shipping and waiting.
    By the way, I am using the 7/8 Jeep slave with a 62 truck master with a 1-1/8 bore. Works fine.
  28. fstfish66
    fstfish66
    from eastern pa
    nice kit,thanks for posting ,some intresting and valueable info on that site,, :cool:
  29. Geoffav
    Geoffav
    Awesome, this thread made my day. I can't seem to search fast enough here, great info so far. :cool:
  30. I'm surprised that no one has suggested a complete factory setup out of an early 60's chevy / GMC truck. It is the dual master setup, but would work fine on a single master and it moves the slave and throwout to the p*** side where there is more room. Now I'm ***uming that he is using a SBC as he didn't say what engine and this setup won't be in any Great Britain junkyards, but they are common at swapmeets here and cheap. I've build a few and they are simple.
    Also .....why the hydraulic?? I've also built a 51 F1 with SBC and muncie and just a mod to the Ford cross shaft allowed a mechanical clutch linkage that was smooth and easy push. My lady drove it with no complaints. Was all the stock Ford pedals and such but that is still in junkyards here.
