brakes olds/pont rears update on car
Discussion in 'The Hokey Ass Message Board' started by 56olds-ERDY, Aug 20, 2008.
  1. 56olds-ERDY
    56olds-ERDY
    just thought id share what i was working on.for the rearend in my 56 olds im using a 61 olds with impala auto adjusters and 57 chev wheel cylinders.just thought it might help someone out.i used radirs with 5" backspace,and a 9" wide tire.also had to cut the extra lips off the quarters.car has a 3" drop in the back.just wish i could work on her more.
  2. Ramblur
    Ramblur
    Nice, I've got the same deal on my 57 chevy delivery. 57 Olds axle,with the
    self adjusters,15x8 ARE Ansen slots with 0 offset and 28x11.50x15 MT
    ET Street tire(also9").Only difference is I have the springs moved under/into
    the frame from way back when. Fits great!
  3. Redneck Smooth
    Redneck Smooth
    from Cincinnati
    Ok, I'll bite, I've got a '58 and would love to have auto-adjusters. Can I use my stock hardware with them? What year impala are they off of? I ***ume they work on the front AND back?
  4. Ramblur
    Ramblur
    Yep,front and back.I had new hardware kits laying around for my 63 wagon
    and used those. A worthwhile upgrade.
  5. 56olds-ERDY
    56olds-ERDY
    check out autozone.com.i ordered the whole setup there.
    i ordered them for a 62 impala.i hate adjusting brakes.cant use your stock hardware the top springs are different.good luck
    eric
  6. Paul
    Paul
    Editor
    let me see if I got this straight..
    '61 Olds housing, backing plates, shoes and drums
    '62-'63 Impala adjusters and hardware
    '57 Chevy cylinders
  7. 56olds-ERDY
    56olds-ERDY
    yes but im using 56 backing plates.i cant remember if the later backing plates are the same for cylinder mounting.i think they are.
  8. Stick Shift
    Stick Shift
    from LENA IL
    Oh yea Erdy now I remember why I like 56 Olds. It is all because of you.
    Thanks for the info. I might need this someday.
