Whats a Running 63 390 Caddy go for..
Discussion in 'The Hokey Ass Message Board' started by Evel, Jun 10, 2008.
  1. Evel
    Evel
    Got a friend asking what they go for money wise...
  2. touchdowntodd
    touchdowntodd
    not sure about there... but seems like here $300-1000 depends on who is buying and over all condition and all... i may be way off, hell i may be no good as always! hahha.... seems like a 390 would be worth a lil more than a 331 or 365...
    u should get it for yourself... if its a deal
  3. 1963 is sort of an orphan year for the 390, from what I remember with my Dad's '63...
    Most parts interchange thru '62.
  4. DenverDave
    DenverDave
    from Denver, CO
    There's one in the local pick n pull. I was told they're asking $300.
  5. Flop
    Flop
    your right bigred
    49 to 62
    i think theres some crazy stuff goin on with the 63
  6. Jobe
    Jobe
    from Austin, Tx
  7. G V Gordon
    G V Gordon
    from Enid OK
    Just sold a '59 for $800 if that helps.
  8. cptkid
    cptkid
    carefull, the 59-60 390 are differnt than the 63, the trans from 63 will not mount to a 59-60 or vise versa. very similar but differnt
  9. Noland
    Noland
    one benefit of a 63 390 is it bolts to a 400 trans which is a fairly cheap ******, In that same aspect you could bolt it up to a 4 speed easy and cheaply.
    Caution:Some if not all information could be invalid
  10. notebooms
    notebooms
    Alliance Member
    they're not worth much. i still find 49-62 motors that have been pulled out of cars for free. i have two of them in my shop. the 63 wouldnt be worth more, being a one year cluster ****.
    lots of guys seem to, unfortunately, be pulling the Caddy motors out and putting in SBCs. that's where i got the last two that i found.
    couple hundred bucks, max.
    -scott noteboom
  11. travillac
    travillac
    so has anyone ever actually done a sbc swap? i would really like to do so to my 63 caddy. anybody got any links or info please let me know.
  12. striper
    striper
    You have a SBC in your Caddy??:eek:
    That Caddy motor should slide right back in.
    I paid $300 AUD (that's about $27.50 US) recently for a '60 390. Needs a complete rebuild.
    Pete
  13. travillac
    travillac
    say what? no i dont have one in there right now...there isnt a motor in it at all right now. i was thinking about a 350 just because this 63 390 is such a step-child.
  14. Rich Rogers
    Rich Rogers
    that's alot of car to pull for a 350. Performance wouldn't be that good and prolly mpg would **** too. Just to small an engine IMO. Keep it Caddy
  15. travillac
    travillac
    hmm, your probably right, good point. i will prob just throw the 390 back in.
  16. We are putting one in my son's '64 coupe. 400 sbc with a turbo 400 behind it. The motor is at the machine shop, the trans is having the 4 inch tail shaft changed to a 9 inch. We used '66 chevelle mounts that we switched sides and turned them around backwards.
    The motor sat too high on the frame so it needed cut out and boxed. Now the drive train lines up using the factory drive shaft.
    I'll Post a couple more photos when the motor and trans get back.
