what rear end can I use for my 58 chevy short box
Discussion in 'The Hokey Ass Message Board' started by shawn mann, Aug 26, 2008.
  1. shawn mann
    shawn mann
    from florida
    I'm looking for a rear end that is period correct for my 58 chevy truck.I would like a posi.What year can I look for.thanks :confused:
  2. squirrel
    59 chevy 1/2 ton had an optional Dana 40 with posi. Don't get much more correct than that, eh?
    but a 55-57 chevy car rear with the perches welded on top and a posi chunk would be more hot rod oriented, and period correct, and easier to find...but probably even more expensive....and give you 5 lug bolt pattern, which you can match up front by installing 51-54 car front hubs/drums.
  3. shawn mann
    shawn mann
    from florida
    Thanks but if i was going to use a dana i would keep the dana 60 i have instead,but it's for sale
  4. Deuce Roadster
    Deuce Roadster
    When I did my 55 Chevrolet Cameo pickup, years ago ... I used a 57 - 59 Ford car rear end. It is a 9 inch Ford so parts are easy to find and they have ratios from 2.50 to 4.57 from the factory. Aftermarket goes even to 6.50. I used one from a station wagon. It had the big axle bearings.
    This was in the 1970's ... so the rear ends were easier to find back then. Some folks say that the 57 - 59 Ford rears are impossible to find. Maybe so in their area but my favorite local junk yard still has 8 or 10 :)
  5. Torkwrench
    Torkwrench
    I put a 59 Pontiac in my 59 GMC. Had to narrow it with custom axel shafts though. Also adapted 57 Chevy brakes to it.
  6. JimA
    JimA
    I have one- but it's WAYYYYY over here. What's it really worth Squirrel?
  7. enjenjo
    enjenjo
    from swanton oh
    I just put a 76 Camaro rear in a 58 Apache, fits fine.
  8. squirrel
    I don't know. I have one laying around here that I haven't used. The 3.92 ratio is a bit much and 44 gears won't fit it.
  9. btmatt
    btmatt
    1965 T-bird (9 inch") is in the back of mine. 1/2" more narrow than stock, smooth back, and big drum brakes.
  10. InDaShop
    InDaShop
    from Houston
    I've done three in '58 fleetsides
    All stock width
    '71 Camaro 10 bolt
    '87 or '88 S-10 10 Bolt
    Lincoln Versaisse (Sp?) 9"
  11. I used a unit from a'76 monte carlo
