Projects The Chris Casny Coupe, Model A build pics
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Apr 25, 2008.
  1. scootermcrad
    scootermcrad
    You can't steal it! I'M stealing it first! :eek::rolleyes::D;)
  2. zealot9802
    zealot9802
    from SoCal SFV
    Amazing work Chirs.
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Can't believe I missed this the first time around. That column rules.
  4. solid
    solid
    I love this thread, kick *** fab work. That steering set up is the best i have seen not being a sprint car box. You helped solve some of my problems with my steering. I need to see more.
  5. FoMoCo_MoFo
    FoMoCo_MoFo
    I am proud to call you a MOTHER****ER!
  6. A few updates, nothing earthshattering.
    After making the steering column, and setting the angle that suited me best, I had to notch out the dash a bit.
    I'm running 48-52 Ford F-1 pedals. Originally I was going use a 1940 single chamber master cylinder, that requires 3 mounting holes, but my friend Sandy, convinced me to go with a newer style dual master cylinder instead (those need two mounting holes), just to be on the save side.
    So I decided to make an adaptor to fit the F-1 pedals to the newer/safer MC.
    I basically took a piece of 1/4" plate, drilled holes for both hole patterns, tapped the holes, inserted the 3/8" bolts (heads cut off) and tig welded the back side, so nothing would come loose, later on.
    Voila everything just bolts together.
  7. Mounted/mocked up the headlights and grill.
    It is starting to look like a Hot Rod.
  8. SinisterCustom
    SinisterCustom
    Outstanding work......nice details.....CLEAN!
    What are the headlights? The signal pods are taller than most I've seen....
    The 2nd to last pic above....it looks like the grill shell is a little low?
  9. The grille shell could be higher, huh. I appreciate the input.
    I think 1" higher would work.
  10. K13
    K13
    I would agree. The tape looks ok but it is up on the radiator cap opening. I would thnik you want the line from the cowl to the back edge of the grill shell to be in line. I would think and inch would be perfect.
  11. How is this, 1" higher than before.
  12. SinisterCustom
    SinisterCustom
    Still looks low....to me....Another 1/2? Maybe???
    Sorry Dread..haha
  13. That's alright. This stuff has got to be right.
    Here is another 1".
  14. Reading this has given me so much motivation. Great craftsmanship keep up an amazing job.
  15. SinisterCustom
    SinisterCustom
    STOP!!! I think that's it man!
    How 'bout takin' a pic from a little lower?
    Tell me to shut up anytime.....
  16. thekid54
    thekid54
    Damn Chris, it looks incredible!
  17. Here is the same grill height, shot from a lower angle.
  18. Ian Berky
    Ian Berky
    hey chris! i just finished lookin' at the whole thread and wow!!!!!!
    amazing work and skills my friend! BEAUTIFUL!!!
    see you around!!
  19. scootermcrad
    scootermcrad
    I think it should go up 1/8". ;):D
    RIGHT THERE! I think that's it...
    Do you need to put any weight in the rear to see if it changes things?
    Man that's lookin' great! It's always cool when you get the grille shell up there so it looks like a car!
  20. jerseyboy
    jerseyboy
    Dreadman, nice job, great details! Did you fab those headlight stanchions? They look like they have a real nice cross section. Those headlights are sweet:cool:
  21. No, I didn't make those, but I fell in love with those headlights at the Primer Nationals, a company called OTB gear, www.otbgear.com makes them, ultra high quality.
  22. jerseyboy
    jerseyboy
    How about what the headlights are mounted on? Did you fab that part?
  23. Justin B
    Justin B
    can't believe if missed the posts on this thing, it's coming along great.
    oh yeah to make the grille 100% just put a level on the bottom of the door gl*** opening or belt line, and set the grill to cowl line at the same degree.
  24. No no, those are "el cheapo" Speedway cast aluminum ones.
    I don't make everything.
  25. Gepetto
    Gepetto
    from Orange
    I am joining the club by saying that I can't belive I missed it the first time. The car is coming out great and looks as though it wont be long before its done. Nice work man.
  26. jerseyboy
    jerseyboy
    Thanks Chris!:D
  27. Exhaust:
    Lake pipes. I used exhaust flanges made by "Hot Rod Ch***is and Cycle" www.hotrodch***isandcycle.com/parts_cars.php , solid stuff, highly recommended, and a SBC lake pipe kit.
    I never liked how some guys just run straight pipes into the "cone", I went a slightly more difficult route, and more esthetically pleasing, I think (thanks to the Tardels and Sellers, for the inspiration).
    Cutting the "duck bills" was time consuming, but in the end well worth it.
    I basically cut all the "bent" pipe, with a cut off wheel.
    Ground everything to the desired shape/contour. I also used a big round file, to make them fit perfectly.
    The radius on the "duck bills" vari, because I'm using a tapered cone, so patience comes into play, and lots of it.
    Check it out, I did one side today, "all day" and I'm still not finished, but I will get the exhaust perfect for plating, if it's the last thing I do, damn it.
  28. Bad Bob
    Bad Bob
    from O.C. Baby
    Pipe looks great Chris! Those headlights worked out good too! Nice work,like usual...
  29. ratster
    ratster
    build me a pair?
  30. Church
    Church
    from South Bay
    Looks killer Chris. I can't believe how sweet it will be with those heartbeat graphics when it's all painted. You're a visionary!!!!!!!!
    Seriously dude. Magnificent work. Can't wait to see and hear it.
