Holley Trouble
Discussion in 'The Hokey Ass Message Board' started by nayrlloyd, Aug 29, 2008.
  1. nayrlloyd
    nayrlloyd
    from Georgia
    Has anyone ever heard of or seen cracks in a metering plate??? I have a Holley Truck Avenger carb. It had been running fine for about 2 years, then I started having problems. I took it to a mechanic who found the cracked (rear) metering plate. He swapped it out and put it back together. It worked fine for about 100 miles, then started acting up again. This time I dis***embled it and found the same thing.
    Has anyone ever seen this before? I've searched the whole internet (yes, THE WHOLE INTERNET!!!) and can't find any do***entation of this. Any help would be greatly appreciated.
  2. louietrucks
    louietrucks
    from Atlanta ga
    I have seen it a couple of times. One on a used carb I bought no idea what happened. The other a buddy had a 23 T with a 351 clevland and it was running good then cranked it one morning and like holleys do with no choke (ok all carbs) it poped and cracked til it warmed up good then ran like junk. figured it blew a power valve replaced it still ran bad we tore carb down and started looking and found the long diag. p***age that takes fuel to the squirter was cracked up its length. Replaced metering block and all was good. So has yours backfired through carb hard lately?
  3. nayrlloyd
    nayrlloyd
    from Georgia
    Wow, can't believe someone has actually seen this before. I'll check the power valve and look for the diag. p***age way you're talking about. Thanks a million.
    BTW, I noticed you're in ATL. I'm in Suwanee - you close by?
  4. louietrucks
    louietrucks
    from Atlanta ga
  5. scottybaccus
    scottybaccus
    I've had one. I wound up surfacing the back of the carb to make sure it was flat with a file. Over tightening the metering plate with any warpage in this joint will keep breaking them.
