How many cfm are holley 94's?
Discussion in 'The Hokey Ass Message Board' started by ThatOne49, Aug 31, 2008.
  1. ThatOne49
    ThatOne49
    How many do you think a 327 needs?
  2. skunx1964
    skunx1964
    stock motor or what? need details....
  3. hotroddaddy
    hotroddaddy
    from jax, fla
    Depends on what you want the motor to do, and how it`s built. If it`s a stock motor you probably could get away with one or two, but there are way to many variables to give an accurate answer on that one. Hint, give more info.
  4. ThatOne49
    ThatOne49
    68 vette 327 /w 64 vette fuelie heads, 60's Edelbrock tunnel ram (tr1yx), open headers, stock internals I believe.
    Need any other info?
  5. skunx1964
    skunx1964
    3 would be fine, maybe a staggered 4 carb setup. or 6, whatever you want really.
  6. jj mack
    jj mack
    Hello Mr Thatone49.
    There is a search function and and many threads about holley 94s and how many cfm you need.
    The answer is ....It depends.
    First you need to decide how much your engine needs...what are you gonna do? Race or just cruise?
    To calculate it use this formula...
    CFM= (CID x RPM x Volumetric Efficiency) divided by 3456
    so if you need to run 6000 rpm and get 85% VE you need 483 CFM. so you need ~160 cfm per carb to run 3 carbs.
    94s have a wide range of cfm outputs. Search on here for Holley 94 and you will find out which holleys you need as the go from ~150 to 205 depending on the model.
  7. 1951bomber
    1951bomber
    from atwater Ca
    3 is all u reall need anything more just gets to be a h***le
  8. panic
    panic
    Remember that this is at 3" Hg. vacuum.
    Is that what you want?
    I'm sure everyone already knows what I think of the "formula"....
  9. Irish Dan
    Irish Dan
    For Whatever It's Worth, multi-carb set-ups work best on a sbc when they're NOT in a staggered position. If you've got log manifolds, & the carbs are side by side & positioned straight across from each other, they'll work quite well on a progressive linkage. When they're staggered, you're always feeding the nearest port on the heads while starving the port not directly in line with the carb. Long story short, you're not running a balanced flow on fuel delivery, & they always tend to bog with an excess of fuel on some of your ports, and fall down with an absence of flow on others. I've been down this road before, & learned from trial & error. I just hope I've adequately described what one can expect when running a staggered carb system irrespective of what CFM those carbs might be. Comprendo?...I hope so! My 2 cents only!
