1958 Ford 9" wheel Bolt pattern???
Discussion in 'The Hokey Ass Message Board' started by HellRaiser, Sep 1, 2008.
  1. HellRaiser
    HellRaiser
    from Podunk, NE
    On a 1958 Ford car, what would the wheel bolt pattern be? 5 1/2"....5"....4 3/4"...or 4 1/2". All would be the five bolt hub.
    Would the data tag have all letters and no number? The info I have, the tag sould be all letters.
    Got one that supposedly come from a 58 Ford car. It measures 4 1/2" X 5. and the data tag said 3.56. nothing more.
    Something doesn't seem right according to the info I have about 9" rear ends.
    Thanks,
    HellRaiser
  2. shoprat
    shoprat
    from Orange, CA
  3. 50shoe
    50shoe
  4. HellRaiser
    HellRaiser
    from Podunk, NE
    Thanks, 50shoe. That article identified it by the tag as a early 9". and by the tag, (which I have, as 3.56 gears, as according to that article), Ford did not use the lettering system on their earlier tags, only the gear ratio in numbers.
    HellRaiser
  5. FORD FAN
    FORD FAN
    I have the same 9" in one of my cars. It's out of a '59 passenger car. 28 spline, small bearing, 4 1/2" bolt pattern. Also 3.56 gears, non locking
  6. lakes modified
    lakes modified
    If it's out of a pickup, it will be 5 on 5 1/2.
  7. chaddilac
    chaddilac
    It can be whatever you want if you redrill it! :D
    What up HR....
