O/T What the heck is this ?
Discussion in 'The Hokey Ass Message Board' started by swade41, Sep 8, 2008.
  1. swade41
    swade41
    from Buffalo,NY
    Some kind of Morris code machine ?
    any idea what this rim fits ? this could be 30's Hudson
  2. lucky_1974
    lucky_1974
    I believe that is an early black box flight recorder from a rare 1928 Henway,
  3. kerrystagmer
    kerrystagmer
    from MD, USA
  4. Mazooma1
    Mazooma1
    movie projector
  5. gearjam1
    gearjam1
    Hmm...bet it's WWII. I have a '26 "Henney", and it doesn't have a flight recorder. I'm jealous.
  6. 61TBird
    61TBird
    i don't know,but,i'll give you $5 for it....
  7. borndead327
    borndead327
    enigma machine lol
  8. Dan Hay
    Dan Hay
    I dunno, but that's a VW Bus behind it. :)
  9. Zig Zag Wanderer
    Zig Zag Wanderer
  10. I think Mazooma1 wins.. it's a movie projector..
  11. That's a secret message decoder from the Major Astro Days. I sent my $0.49 off in 1965 and didn't get **** >>>>.
  12. swade41
    swade41
    from Buffalo,NY
    you guys are killing me..lol
    how about a 16 inch 4 lug artilary wheel ?
  13. Hey was that a bottle capper in that pic??? >>>>.
  14. squirrel
    the tag on it, behind the right side of the reel, says SIGNAL CORPS and has some more info...that will probably tell you what it is. maybe you could take a close up pic of the tag, or at least post what it says.
    looks like a punched tape reader.
    neat stuff
  15. early version of a tape recorder,recorded on wire before modern tape was around.crude but it worked sorta
  16. Mazooma1
    Mazooma1
    That black box on the right is the lamp housing for the projector bulb...
    The film exited out the slot on the top to an external bracket (in the lid) where the take-up reel went. Its 16mm.
    Geez.
    Even this kid knows THAT !
  17. Mazooma1
    Mazooma1
    different model, but similiar
  18. swade41
    swade41
    from Buffalo,NY
    yes it was, I got to clean out a garage today..lol
    how about a gas motor driven generator with junper cables attached, old school jumper box
  19. speedtool
    speedtool
    Not to hijack the thread, but who else remembers Major Astro?
  20. swade41
    swade41
    from Buffalo,NY
    The tape on the reel is paper with running black imprint like a mountan range, I just couldn't see the projector light showing that to be anything.
  21. Mazooma1
    Mazooma1
    OK, I'm stumped, then. No bulb or a bulb socket in the black box gizmo?
  22. squirrel
    What is the nomenclature? (the funny numbers/letters on the SIGNAL CORPS tag)
    Looks like the light shines thru the tape, onto a detector tube. Since it has a black line instead of holes, it's probably an ****og device.
  23. Mazooma1
    Mazooma1
    Can you give us any info on any tags, labels, inside or out???
    Manufacturer, etc. ?
  24. swade41
    swade41
    from Buffalo,NY
    Give me a few minutes, it's out in the garage.
  25. Hey speedtool, were you watching the day he bumped his head coming through the door " before censorship "???>>>>.
  26. 2-TONED
    2-TONED
    the car jumper is pretty neat. someone with an old shop or gas station needs that.
    get it running, drag it through the deep snow (as it looks to be a low rider) restart it when you get to the car as a couple times it was upside down in the deep snow while dragging it there & it died. get the cables hooked up, sit in the car while it charges (probably not too long) fire that car up & move it so we can plow the lot! then drag er back into the shop. ---------
  27. Dude you must not have clenaed your garage for a long *** time. You got any cars stashed in there??? >>>>.
  28. Early lathe and milling machines ran this way. A black tape with a series of holes,dots,dashes,and so forth to tell the machine what to do,when to change the tool head,how much to cut,and so forth. These were the early cnc machines. Worked great until something went through the tape and gave a false reading. Then all hell broke loose >>>>.
  29. swade41
    swade41
    from Buffalo,NY
    Signal Corps
    KEYER TG-34-A
    115/230volt 50/60 cycle A.C.
  30. swade41
    swade41
    from Buffalo,NY
    no cars but found this sweet drill press
