28/29 Dash Panels
Discussion in 'The Hokey Ass Message Board' started by tmacracin, Jan 20, 2008.
  1. tmacracin
    tmacracin
    I would like to stick with the stock panel on my 28 closed cab pickup. What size of gauges can you run it the stock panel? Is there enough room cut out the oval hole to run a 3 3/8" speedo? Got any pictures with this done?
  2. Yes there is. I have a magazine article right here showing the whole process! That is what I plan in my A with the tach on the column.
  3. tmacracin
    tmacracin
    I just bought a Mooneyes tach for the column also. What mag is doing the article?
  4. RichardW
    RichardW
    I know it isn't the same but I am using the original panel for my '31. On top is the original float gas gauge, where the key was is a 1 1/2" mechanical from one of those cheap 3 gauge sets and where the amp was is the oil pressure. Of course I had the round speedo and it is now filled by a 2" Dakota Digital. I went with the DD simply because it was the easiest and most flexible because it can be recalibrated easily.
  5. tmacracin
    tmacracin
    A buddy of mine gave me some brand new gauges he had for years this afternoon. The speedo is 3 3/8" and the three oil press,temp,volt gauge are all 2 1/16". I hope I can make the stock panel work I like the look of them.
  6. Crestliner
    Crestliner
    I had one of these, but just gave it to my son. He is putting it on (can't say it here) you know where.
  7. tmacracin
    tmacracin
    Is anyone making those panels anymore?
  8. Crestliner, that is a way cool panel! Accessory panel? Afterrmarket. You can say Ebay, we do all the time. Ebay Ebay Ebay
  9. Crestliner
    Crestliner
    I havn't been able to find anyone making them and yes they were aftermarket. I was going to put it in my 30 roadster, but it has the round speedo. No problem, so I thought, change the speedo. Wrong! Dash is different. My sons not working right now, so he could use the cash.
  10. That is one of the coolest pieces I have seen.
  11. SUHRsc
    SUHRsc
    sorry this isnt the best picture
    I filled the original speedometer hole and then drilled all 4 spots for stewart warner modern wings gauges
  12. tmacracin
    tmacracin
    That looks good also. I kinda want to keep them all in the center panel and have the tach on the steering column.
  13. MattStrube
    MattStrube
    Sacto Vintage sells a unit that you can add two guages below the stock guage cluster. There isn't much room behind the stock A cluster...not sure if you'll be able to find a guage that'll work unless you plan on not using the gas tank.
  14. tmacracin
    tmacracin
    No I'm not using the stock fuel tank so I will have lots of room.
  15. yblock292
    yblock292
    I did it on a 30-31 its tight but it works.
  16. Crestliner
    Crestliner
    That is what I had to go to on the roadster. Don't like it as well, but will work until I run across like mine for a round speedo.
  17. tmacracin
    tmacracin
    Got some pictures?
  18. tmacracin
    tmacracin
    I'm on the search for another set of guages the speedo(3 3/8") I have is too big to fit the other 2 1/16" gauges all in one spot. I found this pic awile back but have no idea what size they are? Anyone else done this setup before?
  19. gashog
    gashog
    I'm using the Smith's dual mechanical temperature/oil pressure gage they used in the 60's Brit cars in the stock cluster (2 inch). Had to make a new faceplate to cover the stock speedo hole and dimple the tank just a tad (I'm using it to gravity feed the flathead). The column mount tach/speedo are from an MGB GT.
  20. xlr8
    xlr8
    from Idaho
    That accessory panel was called an Aristocrat. There is a company that I believe is called Westech making a guage set to fit the original panels.
  21. StevenPud
    StevenPud
    here's the one i did...autometer 2 1/16" gauges and 3 1/8" tach...
      27.1 KB
      41.2 KB
      46.8 KB
      50.1 KB
  22. tmacracin
    tmacracin
    stevenpud
    That is what I'm thinking.it looks good
