Hot Rods Wheres my Vin located?
Discussion in 'The Hokey Ass Message Board' started by 41DeluxeRat, Sep 13, 2008.
  1. 41DeluxeRat
    41DeluxeRat
    I need to get a Vin check to register my 41 plymouth special deluxe. i see a plate riveted to the firewall, but its blank, theres another that sayd "body number" and has a number but its not even close to the same format as the VIN on the ***le. is the vin on the other tag and maybe just worn off? Are there any other locations i could look?
  2. skidsteer
    skidsteer
    I am not familiar with the '41 Mopars, but from previous posts for various Hamb'ers cars, a common location seems to be on top of the frame, in front of the firewall body mount. You may have to clean off a couple pounds of grease and dirt, but at least it's a start. Try the p***enger side first.
  3. gtnrkix
    gtnrkix
    I believe a lot of cars actually used their engine number. Not much good on a rod!
  4. 37hotrod
    37hotrod
    On the Super Deluxe model (P12) the vin is located on the right front door post.
  5. 55 dude
    55 dude
    post the numbers you have on your ***le and somebody could tell you if they are engine numbers or ....
  6. 41DeluxeRat
    41DeluxeRat
    the numbers on my ***le are like 113503500 (maybe not those numbers exactly, thats just off the top of my head, but its close). I looked at my engine numbers already, they're *p12*454733*.
  7. 41DeluxeRat
    41DeluxeRat
    Good news! just checked the door post. its there and it matches! thanks guys!!!
  8. skidsteer
    skidsteer
    Glad you found it! Today I just came across a Mopar parts site that said '42 and earlier is right front forward doorpost, and '46 and later is left front forward doorpost.
