Hot Rods 302 idles great w/choke closed?
Discussion in 'The Hokey Ass Message Board' started by oldfart, Sep 18, 2008.
  1. My Ford 302 idles like ****,but if I close the choke almost all the way,then it runs much better..Not only when I 1st start it but when its up to operating temp. WTF?
  2. Frank
    Frank
    Vacuum leak very likely. Possible weak fuel pump?
  3. billbrown
    billbrown
    va***e leak. check the intake and the carb. did you put a base gasket on?. spray chok cleaner along the mating surfaces of the engine and the intake manifold witht the choke open. Im fat.
  4. skwurl
    skwurl
    Possibly a blockage in the carb also
  5. temper_mental
    temper_mental
    from Texas
  6. d2_willys
    d2_willys
    from Kansas
    Vacuum leak, could be anything that uses vacuum (brake booster, vacuum amplifier, smog junk. Don't forget stuck PCV.
  7. Mr. Creosote
    Mr. Creosote
  8. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    Did anyone mention a possible vacuum leak?:D
  9. I guess vacuum leak wins. I am old school and believe that permatex is gold,however I know that when the intake gaskets were installed,(by a "professional?)it was done using blue RTV only on the small gaskets on the front & rear,none on the intake at all.I expect that to be the reason for the leak.The engine is almost 40 years old,should'nt a gasket sealer have been used?Should I pull the intake & do it over?? When I 1st start it,there is a noise coming from the front of the engine that could be a vacuum leak that goes away when the engine warms up.
  10. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    this is a matter for many, many debates.
    I prefer to use edelbrock gasgacinch, with a touch of r.t.v. around the water ports. I always use r.t.v. instead of the end gaskets. having torn apart about 2500 factory fresh top ends, I can say that g.m. and ford both do not use any type of sealant there at all.
    use good gaskets, and there is no problem. if You use **** ones, or they are the "steel shim" type, better get some pookey on there.
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    possible that your main jet is plugged..never use RTV on carb or base gaskets..RTV hates Gas
    But as far as the choke closed running deal..I just got done with an engine that had the same problem..I found **** in the carb..and the main jets were fouled pretty bad with the ****. pulling the choke enrichend the mixture enough to keep it running..although like ****..it did keep running. Once cleaned out of all the grabage it ran fine.
    sorry just re read your discription..only when at Idle?..than its the idle circuit that is full of ****..
  12. SlowandLow63
    SlowandLow63
    from Central NJ
    Thats not it, its probably a vacuum leak! :)
