Anyone Using Aircraft Gauges in their Rides?
Discussion in 'The Hokey Ass Message Board' started by rodknocker, Sep 19, 2008.
  1. rodknocker
    rodknocker
    Just curious if this was a popular thing.I just picked up an intercom panel from a B-52D Bomber, to use as my "switch" board.I'd like to see some pics if anyone else has gauges and such.
  2. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    It looks a bit basic for me, what about using some 20's to 40's old radio parts? Think old A****er-Kent stuff.............?
  3. squirrel
    I've seen a few pics in 50s magazines of rods with a row of surplus aviation gages in the dash.
    I even went shopping for gages at the gift shop at the Pima Air Museum (tucson) last time I was there...but it was all late model stuff. I need to hit some of the aircraft salvage places there.
  4. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    There's some neat stuff out there Squirrel! Maybe after my surgery we can meet up and do the salvage and lunch thing. And we are coming up on the nice weather now!
    Maybe we can find something cool Rodknocker would enjoy as well!
  5. chromedRAT
    chromedRAT
    i never made it farther than buying a few of them, but the problem i have in my mind is getting the 12 volt car system to jive with the 24 volt system that the gauges use, if they aren't manual.
  6. CheaterRome
    CheaterRome
    from URANUS
    This is from one of our fellow Cheaters Mike Lange. He has a pretty neat 32 5 window and yes all of the gauges work.
    As appropriate and loved as a ***** in sweatpants.
    Jerome
  7. chromedRAT
    chromedRAT
    well how the hell'd he do it then?
  8. CheaterRome
    CheaterRome
    from URANUS
    The backs of some of the gauges were changed to a more simple mechanical when appropriate..
    The speedo is actuated by a pitot tube tucked into the left front frame horn.
    Tach is mechanically driven off the back of the generator with its own gear mechanism that he machined.
    The other stuff ummm if I remember correctly what he told me was ... he dropped down the voltage and used / spliced the same senders that you would use in a normal car.
    I mean really... This dude made the supercharger too... it's a brand new Italmecchanica not a S.C.o.T.
    Mike has some skills
    Hope this helps.
    Jerome
  9. panheadguy
    panheadguy
    from S.E. WI
    why is there a chunk of wood under the gas pedal?
  10. CheaterRome
    CheaterRome
    from URANUS
    Indoor car show Kook rules enforced by local yokel fire department KookS.
    Could only enter the building with a half of tank of gas or less..correct me if I'm wrong but isn't a half filled tank more dangerous with the fumes???
    Had to disconnect battery as well, with and inspection by the FD guy .
    Rome
  11. power58
    power58
    You can never have too many Gauges, ****og Gauges Rule !!
  12. freak dude
    freak dude
    Ive been wanting an altimeter in my car for about a year but the cool looking ones are just too expensive for my budget..If anyones got one cheap I would sure appreciate it...heres a picture of it..
  13. rodknocker
    rodknocker
    thats bad ***, thanks for sharing.
  14. cretin
    cretin
    Here is a couple pics of the inside of "backseat betty" I always thought this interior was bad ***.
  15. Taff
    Taff
    like anything else, aircraft guagea can look great when used properly. when used in badly, they will just look stupid.
    the dash full of airplane guages looks right to me
  16. safari-wagon
    safari-wagon
    I'm running the same B-24 switchgear in my rod. They show up once in a while on Ebag. They work great & the little red ****on can be used as a starter ****on.
    I also found an old fuel pressure gauge that I mounted to my fuel block.
  17. 5window
    5window
    Great car-too many gauges-that's just silly-though I like the gauges. If you check on Ebay, aircraft gauges the genuine hotrod era are VERY expensive. I've been looking for a clock and we are seriously talking $150 for one that doesn't work??
  18. I'm using a fuel gauge from a Cessna Birddog drop tank in the tank for my modified. The red band says "No Take-Off". Also using bits from a Dakota (DC3) and a Huey.
  19. CheaterRome
    CheaterRome
    from URANUS
    Back seat betty's interior is really neat. Fits the car perfectly
    What is the vary large gauge in the center of the dash though????
    Jerome
  20. OshkoshRob
    OshkoshRob
    from Oshkosh
    I've been stock piling aero gauges for awhile now. Can usually pick them up from plane swap meets pretty cheap like $5 a piece.
  21. stealthcruiser
    stealthcruiser
    So he wont give it too much gas!:eek:
  22. Django
    Django
    from Chicago
    To hell with the gas pedal, Mike's dash gives me wood. :D
    Here's a finished shot of Back Seat Betty.
    The Fuel gauge is a B-24. The lights are a recognition lights box. The quadrant is P-47.
    The light at the top is RAF.
    Our shop truck is getting aircraft gauges too. The '27 T roadster is getting all RAF gauges as the owner's uncle built Mosquitos during the war. And of course the Bonneville car will have them too, which is what started this whole obsession for me, at least. :D I've got 2 NOS B-17 radio self destruct switches. They are bad ***. Think they will p*** tech at Bonneville? Hahaha! :D
  23. fiat128
    fiat128
    from El Paso TX
    Neat post. So, I ***ume the airspeed gage works and 140 a "telltale"? Be neat if some of you who have done this would do a tech post on it.
  24. 61Flattop
    61Flattop
    from Indiana
    landing gear lever from an AT-6 Texan would make a *****in gear selector for an automatic or E- brake lever......
  25. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    Every kid's dream, The interior is sick,sick,sick!!!
  26. studedudeus
    studedudeus
    Man, they sure do some wierd s__t in UR****!!
  27. HotRodChassis
    HotRodChassis
    Alliance Vendor
    It's a '36 Plymouth Black speedo cluster. We had it all refitted by United Speedometer, except they changed the fuel level to a fuel pressure (we're running the separate B-25 wing tank gauge) and where it once said "Plymouth" it no says "Air Speed". Oh, and the speed is now 140 where it was 100.
  28. Motoimpaired
    Motoimpaired
    Here was mine. It was not finished yet at the time the picture was taken..
    snopeks garage likes this.
