Ford EEC-IV Engine Applications
Discussion in 'The Hokey Ass Message Board' started by 345 DeSoto, Sep 22, 2008.
  1. What years and engine sizes did Ford use the EEC-IV Contol Module with? I'm trying to determine if the EEC-IV was ever used with the EDIS-8 ignition system. Thanks, guys...
  2. FORD FAN
    FORD FAN
    On Mustangs, 87-93 used EECIV EFI on 5.0 L engines. 89-93 use m*** air. 87-88 are speed density. It will work also on a 351 W. If you're looking to adapt it to a non-ford motor check out a company called M*** Flow. They can set it up on any motor.
  3. fast Ed
    fast Ed
    The only EEC-IV with EDIS that I can think of on a V8 application would be on the 92-95ish 4.6L Crown Vic, Grand Marquis, and Town Car (started in 91 on the Lincoln).
    cheers
    Ed N.
  4. tjm73
    tjm73
    5.0 Explorers used the system.
  5. fast Ed
    fast Ed
    Yes, but that was 96-up, so they were EEC-V with the 102 pin connector.
    cheers
    Ed N.
  6. nitroracer
    nitroracer
    It was used with the dual plug mustang head, those two coils could drive 8-plugs. Why not just megasquirt + EDIS 8?
  7. fast Ed
    fast Ed
