will a 82-92 camero rear end fir under a 54 chevy?
Discussion in 'The Hokey Ass Message Board' started by murf-lostincity, Sep 22, 2008.
  1. murf-lostincity
    murf-lostincity
    i found a camero posi rear end out of a 82-92 i-rock guy only wants 50 bucks
    complete drum to drum even has new brake shoes
    i am going to bag my chevy real soon and am wondering if this will fit under my chevy???
    or should i find somehing else?
    thanks ahead of time .
  2. murf-lostincity
    murf-lostincity
  3. enjenjo
    enjenjo
    from swanton oh
    Yes it will fit. It's a 7.5 ring gear, and not all that strong
  4. Gibson
    Gibson
    from Butler, PA
    wait for one out of and iroc camaro or a gta firechicken, theyre 10 bolts with a LSD and disks
  5. Lotek_Racing
    Lotek_Racing
    Careful there...
    Some IROC rears are a funky borg-warner unit that is weak and has nearly no aftermarket support. You can identify these by their 9-bolt diff cover.
    Shawn
  6. old dirt tracker
    old dirt tracker
    from phoenix
    get your measure tape out.i think you will fine it is to wide. i have used the 70-81 rear and it will only work with conservative tire wheel combo. the 82 up rear is even wider.
  7. murf-lostincity
    murf-lostincity
    well i will be running a 307 (it was free) and its what i got
    so i just need it to cruise low and slow
    and its has complete brake setup
    about the width
    what kind of rim tire setup is considered conservative?
    im still not sure what kind of tires i wanna run
  8. zman
    zman
    from Garner, NC
    old dirt tracker got it, to wide...
  9. murf-lostincity
    murf-lostincity
    oh well, called the guy and he already sold it
    guess i'll keep looking
    what setup would you guys recommend that i can easily find complete drum to drum
    that will work for my application
    thanks in advanced
    jim,
  10. rc.grimes
    rc.grimes
    from Edmond, OK
    Like already stated 81 and earlier camaro with conservative wheel and tire. A step narrower and a dime a dozen is 4x4 s10.
  11. Rockit53
    Rockit53
    from Berwyn, IL
    55-57 rears fit, i've got a 55 in my 53.
  12. Rich Rogers
    Rich Rogers
    You're right about that. I have a rear out of an 81 Camaro in my 55 and it was a real ***** getting the right backspacing to put on even 235-75-15 tires on. The 81 is I think 1 inch wider per side than stock and the 82 is even wider. I had to have 4 1/8 backspace on a 7 inch wheel and that just barely made it on the car.
  13. old dirt tracker
    old dirt tracker
    from phoenix
    i like the gm metric rear. 78-82 or so malibu.cutl***, regal ect. around 58". you have to clean off the coil brks. fits well under 37-54 chevys. has the common chevy 5 on 4 3/4 bolt circle.
