FM antennas
Discussion in 'The Hokey Ass Message Board' started by wstory, Sep 24, 2008.
  1. wstory
    wstory
    from So Calif
    I'm wanting to install an FM antenna that will not be visibally apparent and is note a retracting "mast". Someone used to make a product that you taped to the inside of the windshield. It was an attempt to look like the OEM antennas imbedded in the laminated gl***. I plan to attach it to the gl*** behind the painted out edge. It needs to be thin and flat.
    Any leads to such would be welcomed.
  2. Go to radio shack, they have one you can run under carpet, in door panels or in your trunk.
  3. tomslik
    tomslik
    i have a boat one from napa stuffed in the fairing of my electraglide.
    works about as good as the OEM harley one did....
    if you want, i can get you the part # tonight...
  4. bobwop
    bobwop
    from Arley, AL
    the major parts stores, like Autozone and Advanced sell a couple of different styles
  5. What kind of car are you running?
    I always thought I'd stick a standard junkyard fixed length modern antenna vertically inside the Wescott body of my roadster.
    Several out of the way places it could go.
  6. okiedokie
    okiedokie
    from Ok
    I mounted a regular auto antenna under the gl*** running board on my pickup. Works great on FM, not so great on AM.
  7. Lotek_Racing
    Lotek_Racing
    Dakota Digital makes one called the "Untenna" It's amplified and sticks to the sheetmetal inside the car.
    Shawn
  8. I know that portable radios play ok in steel bodied cars.
    It helps if you keep them above the top of the dash line.
    An antenna may work the same.
  9. blown240
    blown240
    from So-cal
    I used to have a regular fixed antenna mounted horizontally inside my bumper. It worked pretty good.
  10. wstory
    wstory
    from So Calif
    Thanks guys!
    I'll check the several sources ya'll have suggested.
    I have heard that antennas under gl*** (regular gl*** or fibre type) works okay for FM. Works inside convertibles and fabric top inserts too. I'm doin this thing on a '56 Ford so I got no fibregl***.
  11. dirtbag13
    dirtbag13
    have bought the cheap ones as listed above at advanced auto before for customers cars and seemed to have worked better than the dakota digital amplified version i had in my personal car
  12. a trick I used in my store for years on STEEL cars was mount it INSIDE the front seat just make sure you ground it......gl*** anything go's
  13. sy1356
    sy1356
    Take the coax cable from an antenna. Cut the antenna end off. Strip off the coating. Be very careful & tuck the fine inner wire between your window & weatherstrip & ground the braided outer cable. Plug the antenna into your radio. **** free hidden antenna.
    I did this on my Dad's "A" sedan & used foil tape to tape the fine inner wire to the header wood. Works better than the factory antenna in my pickup.
    Just make sure the inner wire is not grounded.
  14. Watch the parts store antennas, the cable connection tends to be loose and wiggling the cable greatly changes the reception.
  15. wstory
    wstory
    from So Calif
    I like that. Wished I'd thought of that. I ***ume the layout of the wire does not have to be symmetrical, like two legs of equal distance on either side of the connector. Right?????? I'm gonna give it a try
  16. jrolla2k3
    jrolla2k3
    Any car audio shop worth its salt should carry a Metra brand hideable antenna with the part # 44-UA20 OR 44-UA200. The UA-200 has dual band amplifers which in my experience works a litte better for picking up AM signals. Either of these antennas are conceilable or can be mounted to the inside of the windshield. I have installed many of them on hot rods, restos, and everyday cars with very good success.
    Heres a link for each...
    http://www.audiooutfitter.com/44ua20/metra/p69849.html
    http://www.audiooutfitter.com/44ua200/metra/p69850.html
    Hope this helps!
