jimmy's '31 p/u
Discussion in 'The Hokey Ass Message Board' started by youngster, Sep 25, 2008.
  1. youngster
    youngster
    from Minnesota
    I started a project today for my friend Jimmy.It's a chopped and channeled '31 A pick up. I'm just building the frame and mounting the suspension and he'll be doing the rest. Here's the front cross member in pieces and welded up.
    Got the frame tubing cut and the tapers laid out today. i hope to get the tapers cut and welded in the next day or so. here's the frame as it is now.
    He has chopped the top on the cab and shortened the box to 30". Should be a sweet little truck.
    Ron
  2. Good start. Get busy.
  3. youngster
    youngster
    from Minnesota
    Project update......
    2"X4", 11g tubing tapered back 29" from the front cross member.
    Rear rail tapered 14" from kick to rear cross member with a 12" kick.
    Frame welded and ground. Front suspension next.
    Ron
  4. 60'shotrod
    60'shotrod
    Nice work Man!
  5. dudley32
    dudley32
    really good start...keep the pics comin'
  6. pan-dragger
    pan-dragger
    your off and runnin'
  7. your off to a great start..
  8. blackout
    blackout
  9. youngster
    youngster
    from Minnesota
    just a short up date. we decided to use a '35 axel with '37 bones. the 31" spring was too wide to use a set of A spring perches so i fab'ed these up instead. should work just fine.
    here's the pieces
    one welded and ground. the other tacked.
    ***embled
    going to the rear end next. A rear spring with 4 bars. to be continued:
    Ron
  10. youngster
    youngster
    from Minnesota
    here's a shot of the frontend,
    and the 4bar / A rear spring rearend
    with the cab sitting on the frame
    the truck will be going back to the owners and i'll post pics of it an the trailer.
  11. 60'shotrod
    60'shotrod
    Looks like it'll sit NICE! More great work.
  12. dirtbag13
    dirtbag13
  13. Strange Agent
    Strange Agent
    Looks like it's gonna be a sweet ride.
