oil return on flathead
Discussion in 'The Hokey Ass Message Board' started by HELLMET, Oct 4, 2008.
  1. HELLMET
    HELLMET
    can i put the return line on the front timing cover? or is there a differnt spot? i have a fire wall mounted oil filter . thanks billy
  2. j ripper
    j ripper
    from napa ca.
    i would ***ume it would go into the oilpan somewhere.. i have a truck one set up like this under the bench.. i see no reason to run one of those filters unless it is for bragging rights.. i dont brag much..
  3. lakes modified
    lakes modified
    Usually the oil return is a fitting under the dip stick tube casting. Some had them & some didn't.
  4. HELLMET
    HELLMET
    mine does have something there i'll check it out. so is the timing gear cover not a good idea?
  5. Flatman
    Flatman
    I know the later blocks have a return port in the block, just above the pan rail on the dipstick side. Is the filter still set up as a partial flow?
    Flatman
  6. earlieamodel
    earlieamodel
    from australia,
    im also chasing this but i do not have the return above the dif stick.
    thanks Andrew
  7. jetmek
    jetmek
    early truck pan has the fitting on the dipstick boss and 59-a car pans have it at the front left side of the pan
  8. Bruce Lancaster
    Bruce Lancaster
    '49-53 types have the return fitting at bottom edge of block on left.
    About 1940-48, return was on pan...first couple of years towards front of pan, last few port was part on dipstick attachment casting.
    Kits for earlier cars with no fitting on pan used a hollow bolt either at fuel pump mounting or on front cover for return. Return volume is low, so simply drill out a bot end to end, maybe 1/8 or so, and figure out a way to attach a fitting. A Speedwat 3/8 brake banjo on an intake bolt drilled out would be an alternative.
    To facilitate getting a hole through a bolt, use a drill press...drill a hole in a block that will firmly hold bolt, swith to a smaller drill without movung anything, drill the bolt.
  9. earlieamodel
    earlieamodel
    from australia,
