How can I do this??
Discussion in 'The Hokey Ass Message Board' started by Brian W, Oct 9, 2008.
  1. Jerod Jardine
    Jerod Jardine
    from wyoming
    I'd do the metal spray. We have our clamp dies done to add traction on the benders. It's like a coat of sandpaper. It looks like cast and it will be uniform.
    Ace metalizing in Santa Fe Springs CA does our stuff. I'll try and get a number for you.
  2. Jimmy2car
    Jimmy2car
    from No. Cal
    Maddog got this right. Go to Harbor Freight. Buy small or large needle scaler. It works well.
    Good luck
  3. Brian W
    Brian W
    Wow so many good suggestions! I spoke to the local blaster and they said they do blast with steel grit. It will set me back about $50.00 for the pair. I did try the sandpaper thing with a hammer but it didn't work so well for me. I am going to paint the manifolds with Bill Hirsch cast iron grey manifold paint. I was thinking if I put a heavy coat on and imprinted it with the sandpaper would that work or would it lose it's texture with the heat?
    rc.Grimes: Can you provide some more info on this coating you use? Any names or contact info, where to buy, etc?
    Thanks so much for all the suggestions. I will be sure to post pictures with whatever I end up using to get the desired finish.
  4. The Brudwich
    The Brudwich
    Use a needle scaler. Someone did this on a pair of CNC'd aluminum heads a few years ago and it made them look like stock cast finish heads. Couldn't believe it! I'll try and find a link/pic of it.
  5. oilslinger53
    oilslinger53
    from covina CA
    id set it on the fence and shoot it to **** with high powered air rifle and steel bb's or pellets. it'll gaurantee a very random pattern if its powerfull enough to make the marks
  6. Shaggy
    Shaggy
    from Sultan, WA
    Ive had good luck with a pointed punch, hammer, and rough sand paper atleast on aluminum, might help to skim it with a sandblast
  7. rc.grimes
    rc.grimes
    from Edmond, OK
    [quote
    quote]
    Maryland Performance Coating (410)549-6122
    I know they're not exactly next door but they will be able to give you first hand info on what to ask a more local shop to do. JetHot and a few others make coatings for the exhaust that do the exact thing you're trying to achieve but in a variety of colors and textures. The other bonus is it will hold up damn near forever. They did several fabricated intakes and headers that came out great.
  8. Shifty Shifterton
    Shifty Shifterton
    I'm thinking all that would do is compromise the coating's durability.
    Don't worry about the smoothness so much, once the coating gets some age it'll have enough character on it's own. Good luck
  9. HanibleH20
    HanibleH20
    On the same note, asphalt late model engine builders would cut intakes apart, work on them, weld them back together, and etch them with a type of acid. There were guys who'd guarantee that tech inspectors wouldn't discover their work. That was aluminum, may be a similar method for cast iron.
  10. Toqwik
    Toqwik
    Krinkle paint
