I'm wanting to run frog mouth scoops on my 2G Rochester carbs. But, I don't find a way to put filters in, I've thought about just running some type of screen only, but, will this be enough to keep dust, dirt out of the carbs.
Oh it'll keep out the big pieces of ****erflies, junebugs and other flying insects, and the occ***ional thorn up pebble or hexnut, but dirt and dust...think about it.
Even though those scoops are both traditional and good looking, if you care about your engine internals over the long haul you'll run something else. It's hard to beat laws of physics when it comes to ingesting debris. Another point of reference, whenever I've tried moving filtration directly onto the carb throat it created problems. You need a clean turn where the air enters the carb to prevent issues with turbulence and atomization. The ACs in your avatar are a great choice for both looks and function. No coincidence there's so many in use good luck
When I ran the scoops, sure made a difference in the way the carbs functioned!! Just not keen on running without a filter. So, I'll keep the chrome hats on. Thanks everyone for the advice!!
Flatattackracing has foam filters made to fit in the throat of carb scoops for 97's I don't know if they will fit 2GC's. I have a 2GC, I could check if you are interested.
I tried putting a foam filter sandwiched between 2 screens, ran like ****, realized it was blocking the air tube.
i believe mooneyes also makes a sort of foam screen insert but as stated above not sure if they would work on 2 gc's
Now granted, all this comes from bikes and VW's, as I've never had a multi carb setup on a V8, but I'm sure the same applies. Usually whenever you run a filter vs. open or often times even changine the filter design itself you will need to rejet or tune your carbs, because you are changing the vacuum signal in the carb. With a filter there is some resistance as you pull the air through the carb, which will increase the vacuum signal and draw more fuel into the mix. with an open stack you have less vacuum signal to draw the fuel.
Here's a link to the mooneyes filters: https://www.mooneyesusa.com/Store/p...=1007&osCsid=33639e6811155fe6096a65033b8db76f
