Steering Wheel Repair
Discussion in 'The Hokey Ass Message Board' started by 65fordguy, Oct 21, 2008.
  1. 65fordguy
    65fordguy
    [​IMG][​IMG][​IMG][​IMG]
    What is the best way to repair the cracks??
    Once the cracks are fixed... do you just paint it?
    What do you guys recommend... lol and no smart A. remarks about just buy a new one! Maybe for christmas??:D
  2. R Pope
    R Pope
    Grind them to a "V" with a Dremel, then fill them with epoxy , sand and paint. Works for me!
  3. 65fordguy
    65fordguy
    you have a particular type of epoxy you use?
  4. 65fordguy
    65fordguy
    what about rage gold filler??
  5. willys33
    willys33
    from New Mexico
    I use JB Weld
  6. 65fordguy
    65fordguy
    no problems adhering to the plastics? I checked out the website.. it said wouldnt bond to
    • Polypropylene plastic
    • Polyethylene plastic
      Dont know what type of plastic is on the steering wheel...anyone know?
  7. 55 dude
    55 dude
    bet the local plastic supply house could tell you.
  8. Fenders
    Fenders
    A friend is doing a 40 wheel - he used JB Weld, looking good....
  9. 65fordguy
    65fordguy
    I vaguely remember watching stacey david on Gearz repair a wheels with a 2 part epoxy... dont remember which.
  10. Flop
    Flop
    pc 7 .. 2 part epoxy. ( guess i was think of the later part of the convience store) thanks unkl
    got it at home depot used it on my banjo wheel painted with no problems.
  11. johnboy94
    johnboy94
    http://www.marinetex.com/
    I have used Marine Tex before for steering wheel repair worked great!
    Check out your local marine supply shop.
    Speaking of which I need to get some for my current project.
    Non Hamb oldschool VW trike. It is great for fixing small holes in fibergl***.
    Johnboy
  12. Mercury Kid
    Mercury Kid
    I've heard of using epoxy, JB Weld, bondo, pretty much anything of that sort. Not sure about the long term potential for the cracks to return, but I think if they do, try something different. I've got the same problem on an identical mercury wheel.
  13. Unkl Ian
    Unkl Ian
    PC7 ,let it set up for a couple days.
  14. Flop
    Flop
    yah that its unkl wrong number on my part
  15. i second the pc 7, it's kinda hard to work into small cracks so you need to open them up. jb weld works good but it's runny.
  16. BrandonB
    BrandonB
    from nor cal
    Doesn't POR 15 make a steering wheel repair kit?
  17. Custom54
    Custom54
    I used Marinetex also, works great. Goes on like bondo, and very easy to sand.
  18. banginona40
    banginona40
    Eastwood sells a steering wheel repair kit, Haven't tried it. I have used por15's epoxy putty which is great stuff to have around for steering wheel repair and all kinds of other things too.
  19. TonyVan
    TonyVan
    from Vancouver
    I used a 2 part epoxy on an old Galaxie wheel about 6 years ago, and it's fine. Clean out the cracks - like they say, 'V' it with a Dremel, and then build it up in layers and sand it down.
    I also used Bondo on a VW Wheel once - same process, but the stuff cracked and fell out after about a month.
  20. I used JB weld on this wheel and it had pieces missing
  21. tommy
    tommy
    I did this one in the early 90s with PC-7. It still looks good but it does not sit in the sun for days at a time.I use the high tech hacksaw blade to clean out and undercut the cracks and replace lost pieces. It sands just like the Ford wheel material so it's very easy to feather edge the repairs.
    You can order higher priced kits and wait for them to come or you can go to the Home Depot and do it this afternoon. They do provide you with cute popsicle sticks and paper cups for mixing.:D
    I've done 6 or 7 over the years with PC-7 and no failures yet.
    Real parts stores had one of these on the counter back in the 60s-70s. The sales pitch was to tell the customer to put it on the floor and stand on the wood shelf that was just epoxied to the side of the gl*** bottle. I wonder how many people stood on this shelf. Mine still has the water in the bottle but the sun has faded the food coloring. We called it golf ball glue for obvious reasons.
  22. I remember that display at the local hardware store in the 80s, didn't realize that stuff had been around for so long. Never stood on it, however.
  23. Chad s
    Chad s
    P*** on the POR15 kit. PC7 is easily found locally, and cheaper, and most importantly, better.
    I used the POR15 epoxy putty. Used it, used it properly, and weeks later, it shrunk ever so slightly in a few areas. Being a white painted wheel, no one but me will probably ever see, but after spending a week working on that wheel, getting it perfect, so it looked like original plastic, I was a bit upset.
  24. Hellfish
    Hellfish
    There are several posts on this topic. Just do a search and you'll find them.
    I repaired the big ones with POR15 putty and the tiny, hairline cracks with glaze coat filler
  25. vegas paul
    vegas paul
    from salina, ks
    Most of the repair kits use the same epoxy, just marketed under different names. The cheapest/easiest thing to do is go to your local Bowling Alley and get the stuff they use to fill bowling ball holes when you want them re-drilled. It is the same epoxy - They gave me some for free, and I did mine. Just be prepared for lots of sanding and shaping after it dries. It takes paint great.
  26. hapanut
    hapanut
  27. LAROKE
    LAROKE
    It's been a few years since I bought the Eastwood Kit but, at that time, the epoxy in the kit was PC7
  28. 65fordguy
    65fordguy
    Whats in thet kit that makes buying a kit worth it?
    I have a dremel tool, Im sure Ive got some thing to apply it with.
    So as far as the putty goes... whats the vote... pc7 or jb weld?... If Im guessing right the pc7 is the more popular..
  29. El Caballo
    El Caballo
    from Houston TX
    Yep yep, marinetex is the shizzle. I used it because of it's UV resistance and restored a stock Mustang steering wheel, worked great.
  30. LAROKE
    LAROKE
    When I purchased the kit in june of 2000, it was $34.99 and consisted of the restoration booklet, PC7 epoxy and a steering wheel puller. Overpriced, but I was a noobie. I wouldn't buy it today.
    The new kit is even less of a deal. They've deleted the puller and added a can of primer and pre paint prep. Not worth $50 IMHO. The booklet pretty much gives the same good info you've already gotten in this thread.
