can any one help i.d HC cam spec's
Discussion in 'The Hokey Ass Message Board' started by 303racer, Jan 8, 2008.
  1. 303racer
    303racer
    Hello all
    sorry to be pain but was wondering if any one can help id Harman collins cam spec's number 6742 thanks much
  2. A dial indicator, degree wheel, plywood base, couple of V-blocks (wood is ok) will tell you what you want to know.
    Set things up so you can read lift and duration via the dial indicator and note where the degree wheel is.
    Skip the .050 bit and use .000 as the point of lift to begin and end.
    That'll give you advertised duration which is how cams were rated back in the day.
  3. Flatdog
    Flatdog
    It may be early and I have been known screw up,but cam specs are in crank degrees? I keep a motor mock up just to check cams.I know you can transfer data with math but when I did that way it confused my old brain.
  4. Shaggy
    Shaggy
    from Sultan, WA
    there is a book that is out that has h+c specs i forget the name but they do a few buildups of flatheads
  5. Mr. Creosote
    Mr. Creosote
    A tip I found when checking cams is to make a photo copy of yer degree wheel. You can mark the opening and closing points on it, various lift points and full lift. Its much easier for me as I can see a picture of it rather then looking at numbers.
  6. 303racer
    303racer
    wow thank you every one you guys are great, i will try this out and see what i get hope everyone is of to a great start in the new year
  7. AndersenRace&Restoration
    from San Diego
    I had a list of H&C Cam specs at one time, if I can find it I will post the specs for your specific grind.
    ken
