60 ranchero floor
Discussion in 'The Hokey Ass Message Board' started by 60 ford, Oct 20, 2008.
  1. 60 ford
    60 ford
    Could anyone tell me where I can find the rear floor sections for a 60 Ranchero. I need the panels that would be under the rear seat in a car. Would Mustang panels be usable? Thanks
  2. abe lugo
    abe lugo
    try the ones to a 4dr sedan, you'll have to trim to fit might be the closest thing available.
  3. 60 ford
    60 ford
    I ve already bought full replacment pans for both sides, but I need the rear sections also.
  4. ChrisDP
    ChrisDP
    Mustang floor is completely different. Reproductions are not available. Any 60-65 Falcon or Comet can be a donor for the rear seat riser. I replaced mine last year. Cut through the rockers and the torque boxes from the donor car, then remove them from the thinner seat riser metal after it's out of the donor. If you try to separate the riser from the rocker and torque box inside the car it's easy to tear it up. better to work on it outside.
  5. madjack
    madjack
    Ranchero was built on the station wagon platform. If you look in the bed you'll see a removable panel at the front of the bed, below the rear window. The wagon footwells are still under there. Makes a great toolbox or battery box area by putting piano hinge and Dzus fastners on the panel. El Camino's were built the same way
  6. try Russ Wall at Wall to Wall Falcon Parts
    626.969.8157
