2G..GM carbs. what the heck does that do?
Discussion in 'The Hokey Ass Message Board' started by Von Rigg Fink, Oct 29, 2008.
  1. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ive got 3 of the rochester 2G carbs..all of them have this little "pin like" deal that sicks out of the back of each carb...there is a little spring on each pin pulling tension on the pin like "thing"..one of the 3 dont have this spring.
    the spring is about the size of the spring in a ball point pen.
    what is the deal with the spring? and if im missing one..is it important?
    sorry no pictures..cant get the dam thing to load right..so rather than have a red X picture, i was hoping that i described it well enough.
  2. Von Rigg Fink
    Von Rigg Fink
    from Garage
    gonna try and load it..hard to see it..but its the tiny lil' ****er on the back of each carb, if you look at the front one you can see the "pin" looks like a limp ****..'cause it dont have the spring.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I believe it's a vent, like that bowl vent that some carbs had on the top of the cover that were actuated by a lever that contacted the throttle arm at idle.
  4. Von Rigg Fink
    Von Rigg Fink
    from Garage
    ahh..that could be, wonder what it would do if no spring?
    it doesnt get actuated by nothing..but it could still be a vent of some sort
  5. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    Hell, I don't remember that spring on any of my 2g's. maybe it returns the accel pump?
  6. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I have tied to locate a good diagram that covers this detail to see what its all about..2 of my carbs have the spring on the pin, one does not. I was wondering if I lost a sping in shipping..and if so where i can get one or if i can improvise using a ball point pen spring?..not sure if its critical or if it just needs to pull pressure on the pin.
  7. Fitysix
    Fitysix
    from Md.
    PM ****ster27...he will know.
    Fitysix
  8. Von Rigg Fink
    Von Rigg Fink
    from Garage
    im gonna Pm ****ster
  9. Von Rigg Fink
    Von Rigg Fink
    from Garage
    dam 56 you read my mind i typed that the same time you did..
    he must be the man to know
  10. Von Rigg Fink
    Von Rigg Fink
    from Garage
    did yours work ok?
  11. Mopar34
    Mopar34
    I got a 2G tri-power setup and don't have a spring like that. Mine runs fine and has for the last 52 years.
  12. blackout
    blackout
    That device is for smog. It is on carbs from about 64 - 69, roughly. The early V-8 carbs had breathers with little round caps above the float bowls. The later carbs had a vent that is acutated by the linkage.
  13. It is called a hot idle compensator. later carbs didnt have them. I learned carb work overhauling those very carbs 40 + years ago under the watchful eye of my Uncle who was an absolute genius with carbs and ignition. It doesnt require anything on yorpart other than cleaning and re***embly the same as that part is installed now. Early 60s BTW
    Don
    Don
  14. Von Rigg Fink
    Von Rigg Fink
    from Garage
    So..if one dont have the sping..its not an issue?
  15. Von Rigg Fink
    Von Rigg Fink
    from Garage
    a few better pictures..well somewhat better..lol
    first one shows the spring..second one the lack of a spring
  16. Abomination
    Abomination
    For God's sake, don't pull the pin!!!
    I hear they explode very shortly afterwards...
    ~Jason
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    lol...great!..now ive got Taliban carbs:eek:..now wait a second..these were made in the USA!
  18. Abomination
    Abomination
    You've got it, man. They're for killin' Commies. :D
    ~Jason
  19. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thats right!..and we sure know them Commies need some killin';)
    before someone gets their ******* in a bunch..were just f-ing around...gee cant even have a bit of fun with out worring that some one will get all PC on your ***:mad:
  20. oj
    oj
    Hey VonRigg, i'm working on a set of those right now off a 65 GTO. These don't have that circuit, i think to elimate the springthing you should replace the throttlebody gasket with one that dosn't have the 2 vapor slots in it. Then you can plug the outside. What'd the ****ster say? Seems like there should be something else against that spring. Let us know.
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    ****ster hasent answered me yet..oh I dont feel like ****ing with it..you know the old saying if it aint broke dont fix it..just curious as why they are there..and if missing one will change anything or not..looks like a very simple fix if it is a necessary part for it to function correctly..
  22. tommy
    tommy
  23. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Thank you very much Tommy..I have been looking at some old service books I have, and had not yet ran across this particular set up..yet.
    Guess i need to find one of those springs..maybe ****ster may have one.
  24. tommy
    tommy
    ***uming you are going progressive, I'd put the best one on the center carb and not worry about the end carbs. You could plug the p***ages with epoxy on the end carbs. It's there for a better idle under very hot conditions. Not needed on the dumper carbs.
  25. dickster27
    dickster27
    from Texas
    Hey guys. The real skinny is it's a useless piece of hardware that Rochester made to keep GM happy. Take the 2 little, teeny, weeny, tiny screws out of the plate and strip the spring plunger and ring out of the plate. I don't eliminate the plate cause it makes the carbie look like ****. So, now take a little sheetmetal screw and fill the hole the "limp ****" was in and replace the plate with a new gasket supplied in the rebuilt kit. That's my story and I'm stickin' to it.
  26. Von Rigg Fink
    Von Rigg Fink
    from Garage
    cool thanks ****ster..if i just run it like it is ,,no ill effects?
  27. chickenridgerods
    chickenridgerods
    from DSM, IA
    Glad this thread came up, as "Dad" has a tri-power setup that had one of those springs and plungers all mangled on the flat end. Hadn't had much luck at finding a replacement. Which years and applications used this version of the carb?
  28. tommy
    tommy
