Just thinking out loud ..... What would I need to consider if I was to cut an A ch***is with a pie cut at the firewall to tilt the front of the ch***is instead of putting a Z in. Obviously the front cross member would need to reworked for the proper angle etc. Would put a fish plate etc. Will it look like ****???? Will I have other h***les???? Whats the correct term for this? Should I just go with the Z? Will Obama win etc etc
Pie cut it just before the cross member to counter the one at the fire wall. Yes a fish plate will look ****, so put it on the inside of the ch***is, then box the frame, thats what I am going to do on my mates frame.
Yep, Done it. Like Fly said just make the same amount of pie cut just behind the cross member to bring it back to the right angle. Things to think of: It shortens the frame very slightly A very big cut will make it look broken Like you said, fish plate and box I think the official name of this technique is "the Bleed Sweep" If you want pics search my build thread (I'm too lazy to find a link, it's late) Pete
