Fitting Lincoln brakes to Ford spindles-tech.
Discussion in 'The Hokey Ass Message Board' started by VAPHEAD, Jun 10, 2007.
  1. VAPHEAD
    VAPHEAD
    I get asked all the time on what it takes to fit the Lincoln brakes I sell to Ford spindles.I was putting together a front end and decided to take pictures!
    Here you see the flat spot on top of the backing plate.
    Standard aftermarket "round" spindles 1937-41 Ford.
    These are CE forged units,little differences between manufacturers.
    Damn these ain't a bolt on! It doesn't fit.
    We need to remove the upper edge of the spindle.
    The backing plate has a graceful bend in the stamping,not a sharp 90.
    Marked for photo where I cut it off..5" grinder with a skinny cut off wheel.
    (Only because my 9 axias 240 volt 3 way self feeding diamond bit mill is in the shop for a tune up.)
    Dress it a little with the grinder.
    Hey ho ! Lookee it fits !
    This front end is using CE bolt through steering arms.
    See the pretty little lock nuts? Hold the head with a wrench and get them not to hit the inside edge of the spindle.
    Brand new 5x5.5 hubs,slip right on..
    And did you notice the 2" wide shoes? Well they match the new 2" wide,radial finned Lincoln drums.That slip Right On .No more swedging!
    That's it.
  2. lowsquire
    lowsquire
    from Austin, TX
    thanks eric,
    Ive just bought this setup from eric for a customers car..its really lovely stuff, all is really nicely machined and fits together great.
    Ive got 37 round spindles for this project, but might hold out for some square backs, and save the roundies for a ford drum front.
    Im ***uming square backs wont need as much (or any?) grinding..
    Buy stuff from riley! hes good people.
  3. VAPHEAD
    VAPHEAD
    Hmm,Steve doesnt know everything! (he really does) not.
    Square spindles with the repop brakes need a little fitting.
    I have a greasy set of squares I don't yet want to modify.
    The top flat of the spindle has a little crown to it.
    That will need to be ground down,
    The top kp boss will just interfere,tried to show in the pictures..
    So a bit more grinding is needed there.
  4. Flat Ernie
    Flat Ernie
    Tech Editor
    Great thread - inserted it into the Brake tech in the archives...
  5. Humpback
    Humpback
    from U.K.
    Does anyone know if these repro Lincoln drums will fit in to a '35 wire? - it looks like they will. I have '40 spindles and '51 backing plates, hubs & drums for 2" brake shoes. The drums are too big for the wires so I'm looking for a drum that will do all the jobs! Any ideas other than the Lincons, if they'll even fit?
    Thanks
    Nick
  6. Sellers Equipped
    Sellers Equipped
    from San Jose
    Then you go and top them off with :rolleyes: Looks good ~S
  7. blackout
    blackout
    Those scoops are art. Man I'm glad there are guys making and or making these parts available. Nice posts.
  8. VAPHEAD
    VAPHEAD
    The Lincoln drums work with wire wheels.
    best to use the little wire wheel support ring.
    F1 truck brakes will not work with wires unless you use a bigger spacer.
    I think Wheelkid has 'em.
    Does this help?
  9. VAPHEAD
    VAPHEAD
    let's see if I can find the pictures..
  10. VAPHEAD
    VAPHEAD
    support ring pictured on old Ford drum,you get the idea..
    drilled backing plates have the standard scoops.
    (I need to carry Sellers...dealer pricing?)
  11. D.W.
    D.W.
    from Austin Tx.
    Right on Mr.Vaphead. Looks great.
    I ran into this after receiving my brakes from Bob Wilson. I remember phoning Reggie Hill to ask his opinion on this & he ***ured me that the world would not end & that it was ok to start hacking the poor little spindles to bits.
    Worked like a charm I tell ya.
  12. Paul
    Paul
    Editor
  13. CGkidd
    CGkidd
    Looks good Eric. I will try to get some pics of mine when I get back to the states.
  14. Humpback
    Humpback
    from U.K.
    Thank you VAPHEAD, very useful. I've just realised you're the guy behind Riley.com. I emailed you last night direct to your site asking the same thing, so apologies for duplicating my question. My set up looks like the middle picture, of the 3 above, and that original drum won't fit the '35 wire. I'll therefore give you a call about buying a pair of your repro Lincoln drums tonight - I'm in the UK. I already have some of those spacers (from Vern Tardel), new shoes and cylinders, so I just need to sort out the drums.
  15. Lookin good Eric, me thinks that Ill be using these for the next project.
    Thanks for takin' the time to post !!
    Rat
  16. myke
    myke
    from SoCal
    Great info! That's exactly how I did mine.
    With 2" shoes also, brake parts and drums bought from vaphead!
