Customs Chevy 350 headers (tight fit)
Discussion in 'The Hokey Ass Message Board' started by Skillings, Nov 7, 2008.
  1. Skillings
    Skillings
    from Napa
    Does anyone have any ideas on what I should do about the exhaust issue I have? The manifolds I have wont fit because they hit the a arm. I have tried different manifolds including the ram horns and they wont work. Put on some nova headers and they just about worked except the rear of the headers on the driver's side hit the steering column. Other than having someone make some custom headers, does anyone know of any headers that might work. I heard that I could run the headers backwards but I havent attempted yet. Oh, and just to get the drivers side header on I had to pull 3 spark plugs to get it to fit..... Is that normal???
  2. skunx1964
    skunx1964
    what car, hows the motor built, ect. details here man......
  3. Skillings
    Skillings
    from Napa
    Sorry, Its a stock chevy 350 motor in a 1955 olds. Manual steering.
  4. skunx1964
    skunx1964
    got a pic of the engine bay, might help. im not familiar with the underhood of an olds...
  5. cretin
    cretin
    Im not sure if they will work on your olds, but the ones I run on my 54 chevy with a 350 are some sanderson blockhugger headers. Pretty tight fit but they work. Worth checking out
  6. Skillings
    Skillings
    from Napa
    no not right now. If there were some headers that roll straight back they would work. The problem is the headers I have now dump where I need them to except they pipes come together 2x2. It is hard to explain. The part where the pipes come together are to thick and is hitting the steering column. If there were some headers that are thinner they wold work. I will try to get pics but My camera is taking a crap and doesnt work all the time.
  7. skunx1964
    skunx1964
    maybe some s-10 swap headers? browse the summit website, they have pics of most and you can search my motor and what yer lookin for
  8. Skillings
    Skillings
    from Napa
    Cretin, those headers might actually work. How much do those cost???
  9. cretin
    cretin
  10. Skillings
    Skillings
    from Napa
    What agout flipping the headers and run them backwards. Anyone ever done this?? Is pulling the spark plugs to get the headers in a common thing??
  11. skunx1964
    skunx1964
    i had to pull my starter, some plugs, wires, all sorts of crap to get mine on, and they were made for my model car. and the exhaust dont care which way it goes, some flatheads went out the front and around under the crossmember and crap.
  12. Skillings
    Skillings
    from Napa
    Cant thank you guys enough for the quick response and the help. It is greatly appreciated.
  13. skunx1964
    skunx1964
