1st car what do you guys think
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by gypsycobbler, Nov 15, 2008.
  1. No_Respect
    No_Respect
    from So-Cal
    I like it! alittle lower than I like but thats my preference. Is that a datsun dash in it? what is the insterment cluster?
  2. gypsycobbler
    gypsycobbler
    from midwest
    its a studebaker cluster and im not sure the year.. picked up at a swap meet.. yea im an old minitrucker and and i just gotta have it low ... its actually about 4 inches off the ground at the lowest point..
  3. cretin
    cretin
    The roadster looks really good. A bit too low for a hot rod in my opinion but I love the rest. Welcome
  4. gypsycobbler
    gypsycobbler
    from midwest
    i was originally gonna put some cut down 32 rails under it like pinkees in colorado does but got talked out of it .. Now im to far into this frame to turn back ..
  5. jagfxr1949
    jagfxr1949
    Dash cluster is '55 Studebaker - I have the same in my '46 Studebaker PU.
  6. gypsycobbler
    gypsycobbler
    from midwest
    thanks for the info
  7. Woogeroo
    Woogeroo
    from USA
    cool car, I love the wheels!
    -W
  8. Fish Tank
    Fish Tank
    YOU ARE ON THE PATH TO BECOMING...
  9. gypsycobbler
    gypsycobbler
    from midwest
    some back half pics.. also headlights
  10. Pretty cool ride there,man -nice highboy -just bustin' ya-great project !
    Good luck with it and welcome aboard !!!
  11. mx6262
    mx6262
    It's your first! Cant wait till you finish it. Makes me mouth water:D
    For sale or gona ride it??
  12. gypsycobbler
    gypsycobbler
    from midwest
    yep first car older than 1963. first attempt at a hotrod i guess u could call it..if the money holds out ill be driving it..fingers crossed thanks
  13. 1919 c cab
    1919 c cab
    from n.j.
    LOOKS good, just keep in mind, ya gota be able to drive it!!!
  14. pinstripingbygato
    pinstripingbygato
    Very cool. Thanks for the detailed pics of the rear. Always cool to see the different ways things can be accomplished, please keep updating and good luck on the funds holding out!! :D
  15. gypsycobbler
    gypsycobbler
    from midwest
    will be posting some more pics got a lot done this weekend but camera broke on friday..
  16. gypsycobbler
    gypsycobbler
    from midwest
    I got one door swinging and latched and floor boards and drive shaft tunnel done .. I got a kugel brake pedal also mounted this weekend
  17. gypsycobbler
    gypsycobbler
    from midwest
  18. gypsycobbler
    gypsycobbler
    from midwest
    sorry
  19. I'll will tell you one thing, you do some nice, well thought out, neat work. I'll complement you on that. I will definitely be following the build of your little roadster. It looks like it's on the way to being a real show stopper if you continue on the route you've laid out so far.
  20. gypsycobbler
    gypsycobbler
    from midwest
    thanks for the comments it keeps up the motivation to be out in the garage welding away..2 finish this project
  21. Zombo
    Zombo
  22. pdc
    pdc
    Good looking ride. What kinda mill will be powering that thing? I'm Paul from Coxs Creek KY. if you need any 60's era engines let me know.
  23. pinstripingbygato
    pinstripingbygato
    I was thinking the same thing, the bracing and the sheet metal work is coming out great.
    p.s. nice seat!
  24. pdc
    pdc
    How about a 327 with a 283 crank? Which destrokes it to a 301. Very common in the 60's.
  25. gypsycobbler
    gypsycobbler
    from midwest
    what up guys i do need an engine the one in there is a loner,,
  26. pdc
    pdc
    I might be able to help. My dad has kept dang near every engine and component. He encountered in his racing career.
  27. I can see a nice Merc flathead in there with Edelbrock or Edmond heads and a dual carb Fenton intake, Beehive oil filter some chrome highlights here and there, be real *****in. Don't go overboard but don't cut the rod short either. You've got too much work in it to go only halfway. You might want to go with velocity stacks on the carbs to get some height contrast.
  28. pdc
    pdc
    How about Hilborn injectors?
  29. They are a bear to run on the street, not impossible just not worth the headaches. Then again, I'm not up on any streetable improvements that might have been made for streetability.
  30. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    nice build,welcome to the HAMB
