Hot Rods Hose clamps period correct one's 40's what are you running.
Discussion in 'The Hokey Ass Message Board' started by HELLMET, Nov 17, 2008.
  1. 32 Barn Car
    32 Barn Car
    from Oregon
    Mine on an Ardun.Sometimes the wire clamps cant be tightened enough to seal.I used the thumb screw clamps on the oil return lines from the heads to pan.
  2. Flatheaded
    Flatheaded
    from Nordakoda
    I used these on my wife's coupe too. Not the "spring" type but I thought they were pretty cool.
  3. Chris
    Chris
    Heres a dumb questions, how tight are you suppost to get those thumb screws? I tightened mine by hand, then took a small cresent and tightened up a little more from there. Well they strip easily??
  4. HELLMET
    HELLMET
    how about the wire that you use a tool with?
  5. 32 Barn Car
    32 Barn Car
    from Oregon
    I also used a small cresent on mine.Never stripped one but they will distort if you try and get them too tight........
  6. alchemy
    alchemy
    Might be hard to see in this pic, but I also used the thumbscrew tower clamps. I bought a large boxful for like a quarter a piece years ago. On the fuel lines I use some old Eelco thumbscrew clamps I stole from a 6-carb hex fuel log. The real thing.
    I usually tighten mine as far as possible by hand, then give them another half crank with pliers.
    As pointed out above, Restoration Supply Co. is a good source for the fuel size clamps, but who makes the radiator size ones new?
  7. Chris
    Chris
    Yep, the ol laquer thinner trick worked great, the writing wiped right off!!!
  8. Here are the ones I have
  9. HELLMET
    HELLMET
    Hey dreadman can i get a few from you for my roadster. Billy
  10. Hubnut
    Hubnut
    I got a catalog in the mail awhile back from a place called restoration supply company somewhere out in california. They had all kinds of old style clamps and just about anything else you could ask for. Not sure that its the same company someone has already posted a link for or not but mite be worth checking into.
  11. HELLMET
    HELLMET
    I have that catalog but i want to see them in person or a good pic before i buy something i dont like or was not what i wanted.billy
  12. GuyW
    GuyW
    I've seen the wire-type on washing machines.
    I bet that Grangers (and similar hardware wholesalers) may have these clamps.
    Me...I like the "new" aircraft SS screw-types...what could be more "hot rod" than adapting aircraft no-fail parts??
  13. KoolCoe
    KoolCoe
    Did you happen to find these at Luky's Hardware? That silver wire through the front of the box looks like a "Luky doing"
  14. mistoo
    mistoo
    from Sweden
    McMaster Carr has the twin ring wire kind
  15. trent
    trent
  16. RPU Rick
    RPU Rick
    KoolCoe, nice camera. Only on the H.A.M.B could one find such detail and fore thought on such a simple item......I Love It. Rick.
