couple questions for you sbc guru's
Discussion in 'The Hokey Ass Message Board' started by pkj, Nov 22, 2008.
  1. pkj
    pkj
    hey guys, i havent played with the sbc since the 70's and have forgotten everything. did my mock ups 2-3 times, but now i am doing final ***embly. my real engine is a 400 4 bolt sbc and has no hole drilled and tapped for the top (12 o'clock) bellhousing bolt. my mock up block did. i am using a cast iron truck housing and muncie 4 speed.
    do i need it?
    what length bolt? (bellhousing to engine)
    what grade?
    lock washers?
    it seems i have been using the HAMB more than my tool box to get this togather. THANKS, pkj
  2. no , you don't need it..i can't recall seeing a block with one there. just use the 6 other bolt holes
    the bolts are 3/8"-NC.....the length will depend on the thickness of your bellhousing. grade 5 will be fine. i like to use lockwashers there
    after thinking about it , i believe that the very early blocks where drilled there..i think the cast iron powerglides used it? anyway , you will be fine
  3. Deuce Roadster
    Deuce Roadster
    You do not ask ... but I hope you know that the 400 SBC requires a different balance flywheel than the other SBC's. I know that original stock 400 SBC flywheels ( not flexplates ) are difficult to find ... but they do exist.
    Hope you have one ... :)
  4. pkj
    pkj
    thanks for the info guys. yes i have the correct flywheel. the machine shop used it and the dampner when they balanced. one thing to note was i had a couple of bellhousings laying around. the first one i cleaned and painted would not clear the flywheel. second one did.
  5. Deuce Roadster
    Deuce Roadster
    Cool ... they do have a large 168 tooth flywheel ... :)
  6. so what ya sticking that 400 in?????????my favorite sbc motor..took years to get convinced to throw one in after years of hi revin 283's, 327's and 350's........got 1 in my 72 vega wagon right now..can ya say torque monster!!!!!!!!!!!!
    either that or a old hemi goinna go into my topolino.....
  7. coopdevill65
    coopdevill65
    from tac ,wa
    that bolt hole on your mock up block was for a b.o.p. style trans.
