Fabbin' a Slingshot intake on the cheap...
Discussion in 'The Hokey Ass Message Board' started by skipstitch, Aug 6, 2004.
  1. skipstitch
    skipstitch
    I've always admired the guys who pioneered speed equiptment. The trial and error must have been rewarding and frustrating all at once. I've been wanting a slingshot style intake for my flathead for a long time and I never seem to have the scratch when one comes up...so... I'm lookin' through one of Don Montgomery's books the other night and the light bulb went off when I spotted an early Edelbrock... And here's what happened 8 hours later. Keep in mind I'm an upholstery guy and I'm sure I'll have to fiddle with the design to get it running right... But that's why it's a hobby!!! First up the supplies.
    -Two 94's... one off the flatmotor, the other a pencil holder with no guts
    -a piece of 1/4 inch plate steel
    -a U-bend of exhaust tubing
  2. skipstitch
    skipstitch
    then I made a cardboard pattern of the carb plate, marking center lines for the bolt holes etc... and transfered it to the 1/4" plate. And headed off to the band saw...
  3. skipstitch
    skipstitch
    Following that I patterned and cut the intake base plate in the same manner. Here it is test fit on the existing stock intake carb mount....
  4. skipstitch
    skipstitch
    After that I test fit for the down tubes... I kept them only 3.5 inches tall so the carbs wouldn't be over my windshield. It also helped in keeping the carbs close together which is the look I am after...
  5. skipstitch
    skipstitch
    Here the down tubes are tack welded to the intake plate and I'm test fitting the carb plate for center/level before welding.
  6. skipstitch
    skipstitch
    Heres the top of the carb plate with the holes cut above the down tubes.... They are small in this pick, but I didn't have a holesaw the correct size...so I'm gonna open 'em up with a die grinder to get them the same diameter as the tubes....
  7. skipstitch
    skipstitch
    The view from the front sittin on the motor... notice how the down tubes stagger to clear one another... figuring that was a bit tricky....
  8. skipstitch
    skipstitch
    The money shot [​IMG] The look is just what I was after. All that's left now it final welding and tapping of the top plate to bolt the carbs. The rear carb will supply one side of the stock intake and the front the other.... The best part, it cost about 8 bucks and I can tweak it to make it work....S***ch
  9. Well that just shot my collection of E-Bay stuff down the tubes.
    Looks doable friend. Now if we could just figure out how to cast it we'd be rich. [​IMG]
  10. NorwegianV8
    NorwegianV8
    from Sem City
    Looks real good [​IMG]
  11. continentaljohn
    continentaljohn
    Cool... great idea [​IMG]
  12. hankcash
    hankcash
    WOW!
    looks like Tech week has finally kicked in!!
    HC
  13. mr57
    mr57
    You want to make me one???
  14. Very, very cool. But I can't tell from your photos. How hard is it going to be to tighten the stud that goes through this hole? Looks like the stud will endup inside the down-tube, or are my eyes just fooling me?
    Thanks,
    Mike
  15. Ryan
    Ryan
    ADMINISTRATOR
    brilliant post...
  16. JSM56
    JSM56
  17. Upchuck
    Upchuck
    from Canada BC
    great stuff!
  18. That RULES....
  19. slammed
    slammed
    Can you imagine what this guy could produce if he were to hang/work at one of the 'pro's' shop's for a month or two in fabrication? Dude, you are good.
  20. Dirty2
    Dirty2
    Tooo cool put 2 of these on on a 2 pot intake great!!!
  21. skipstitch
    skipstitch
    Hey Guys...thanks... And Von Mike, I guess in my haste to get all the pics downloaded I failed to mention that. Good eye you have there. You're right, you tighten that bolt inside the tube (I left Plenty of room for the nut and lock washer) and then you bolt the rear carb in place. I won't be shy usin' locktight on that one!!!
    I'm thinkin' about havin' a buddy of mine powder coat the thing when I'm finished so I don't have to worry about surface rust inside the tubes... S***ch
  22. Boones
    Boones
    from Kent, Wa
    how about another shot from a different angle to give a better view of the lower plateform. Great job....
  23. slammed
    slammed
    Know anyone with s**** Stainless? Polished up it would be dazzling. Well done.
  24. Man, that is unreal! As good as you are with upholstery...you just may have missed your true calling! [​IMG]
  25. S***ch, that is some fine fabricatin' there.
    I wonder if you could incorporate some kind of screen in a gasket when you mount it to make sure you don't lose any hardware in the motor. You might use a self locking nut too so you don't have to keep track of the washer? Great job.
    Dan
  26. My hat is off to you, that is freakin cool, very nice job.
    Greg
  27. Killer
    Killer
    Nice.
    Here's a mock up of one of mine.
  28. bttt...this should be on the first page!
  29. Jeff Norwell
    Jeff Norwell
    MODERATOR
    ...Excellant......... [​IMG]
  30. Nice job!!....I would re-surface both top and bottom mounting surfaces though, heat tends to warp it.
