Valspar Basecoats? Any opinions?
Discussion in 'The Hokey Ass Message Board' started by mikhett, Sep 25, 2008.
  1. mikhett
    mikhett
    from jackson nj
    Is anybody familiar with the valspar line of basecoats? The "zenith" lines are 333& 999. I can get a gallon for 141 compared to dupont chroma for 327.00 The 999 is a 141.00 a gall & the 333 is 119.00. Thanks
  2. SlowandLow63
    SlowandLow63
    from Central NJ
    No experience with it BUT Valspar owns House of Kolor. Food for thought.
  3. voodoo daddy
    voodoo daddy
    from tucson az
    hey look up a paint line called matrix there outa michigan the colors match great and offer quality clears at kick *** prices and they even carry a clear made by 5 star thats tru flat i used to work for a distrubtor of matrix in tucson called paint max the paint is great hella cheaper then dupont. ppg they even do candys perals flakes equivelent 2 house of color
  4. sik_kreations
    sik_kreations
    matrix isnt that bad ur right. ive been spraying the stuff for neaarly 3 years. their kustom fx line is pretty much a copy of hok. it sprays very much like ppg and the clears are nice and around 100 bucks a gallon kit. very cost effective alternative to the major brands.
  5. sik_kreations
    sik_kreations
    thats their cheaper lines. check out de beers. thats their highend stuff. and as far as waterborne, de beers is one of the best out their right now.
  6. David Totten
    David Totten
    Ive used both Valspar and De Beers . Personally I prefer the De Beers it lays down better then the Valspar but is a few dollars more.
  7. inliner54
    inliner54
    Maybe go with Dupont Nason. Paint compaines wouldnt be in bussiness if they didnt make a good product. i like using dupont very forgiving and easy to use. and is sold everywhere.
  8. SlowandLow63
    SlowandLow63
    from Central NJ
    Ha! There's a million (not just paint) companies that are in business and still produce ****ty products. Nason?!?!?!? Thats a joke right?
  9. blackout
    blackout
    I have a car basecoat/clearcoat Valspar, been painted 4 years, looks great.
  10. HighSpeed LowDrag
    HighSpeed LowDrag
    from Houston
    I don't know about the Zenith line per se. but I bought a gallon of Valspar and it was 290+/- from our jobber. Sprayed extremely well. Cleared it with HOK UC35 and looks like gl*** with no cut & buff needed. I was happy that day.
  11. bbc 1957 gasser
    bbc 1957 gasser
    i use it ..333 is a 1 to 1 mix with the 161 ,or 2 so if ya buy a gallon you are getten 2 gallons mixed works well..
    the 999 is there new line its 2 to one it uses the urathane reducer 171,2,3 you get less on the mix it costs more but it covers better ..
    go with the 333 i you will like it ..
    there ac 200 clear is very good to ..
  12. Rusty Kustoms
    Rusty Kustoms
    For a low priced paint you can't beat valspar, I have sprayed both the 333 and the 999 and I love the 999, lays down nice and covers better than ppg, dupont, and most all other high end paints. The clears are great too, my only complaint is their sealers and primers, they are tinted and are a pain to sand, the colorant clogs up 320 grit paper.
  13. Kona Cruisers
    Kona Cruisers
    nice coverage and blending abillity. primers.. average, clear.. b+
  14. loveoftiki
    loveoftiki
    from Livonia,Mi
    Matrix is a PPG Rip Off. Many of thier employees are ex- PPG guys
  15. bbc 1957 gasser
    bbc 1957 gasser
    not really rip off they move some of there products to a lower line diffrent can and sell them cheaper for example
    the dupount v 7500 clear is now nasons 496 clear
    and the primer nason has is dupounts old uro primer
    matrix does the same thing ..
    one bad thing about nason base coats .there catalized so once you mix it its no good you get waste that way ..
    try out mar -hydes 2 -k been useing it on theses gas pumps and this suff is like sprayable body filler sands great wet sands great and the biuld is amazing .
  16. lehr
    lehr
    I've used valspar a few times It works well for me...This car I sprayed with valspar single stage with flattner. The lovely model is my dad....Pat
