Early 50's Pontiacs
Discussion in 'The Hokey Ass Message Board' started by Montechris, Oct 22, 2008.
  1. THE CHIEF
    THE CHIEF
    from MIAMI
    52? thats a 50 grille? wit 52 side moulding
  2. THE CHIEF
    THE CHIEF
    from MIAMI
  3. Nekronomicon
    Nekronomicon
    Heres my little "shed find"
    It was painted green in 76 over the original white, runs the straight 8 and has perfect original red interior.
    Now I've lowered it a bit, put the whitewalls on and oldsmobile caps.
  4. plumfat40
    plumfat40
    from colorado
    Heres a few of mine, with fresh Patina on the front end!!!
  5. plumfat40
    plumfat40
    from colorado
    any one know any wat clip fits 50 ponchos the best?
    <!-- / message --><!-- sig -->__________________
    I like my cars dragging ***, like a dog wit worms
    Mine has a rear steer nova, 68-72 with discs, keeps the wheels tucked and with the sub tucked high in the frame sits low with stock springs and no dropped spindles
    <!-- / sig -->
  6. unclechop
    unclechop
    That is a nice car,Ive not seen any straight Eight 50's pontiacs.(oz delivered)
    According to eddie ford(70s street rodder)there were only 250 brought in in 54,a very small number of those would have been 8s.
    Whats it drive like?
    I changed the diff ratio for 56 pontiac 3:63 (better on the freeway but painfull on take off)
    Let me know if you need any bits I dont have much I may be able to source some.
  7. april may
    april may
    Bare....
  8. Montechris
    Montechris
    Hey Plumfat40, I like the stance of your car, what are your suspension stats?
    -Chris
  9. plumfat40
    plumfat40
    from colorado
    It has a 68-72 nova sub, I graft it on as high in 53 frame as possible, stock springs and spindles, rides like a dream, rear is same deal, nova springs inside of frame, granada 8inch rear,
  10. THE CHIEF
    THE CHIEF
    from MIAMI
  11. nwheels
    nwheels
    from Washington
    Cut a coil and a half out of the front, the rear has 4 leaves yanked with 3 inch belltech blocks and u-bolts in the rear. The rear has been dropped about 8 or 9 inches from where it sat stock when I got it.
  12. Montechris
    Montechris
    Does anyone know how involved adding a dual master is (53 chieftian)? My master might be bad, and i was reading ofton people would use early 70s truck dual master cylinders. I'm told these are about 30 bucks, and safer too. Any thoughts?
  13. Montechris
    Montechris
    Anyone on the MC Question?
  14. Nekronomicon
    Nekronomicon
    Thanks for the offer mate, dont need any parts at the moment but once i start pulling things apart im sure something will come up.
    As for driving, it drives fine, really smooth. Does take a bit on take off but yeah, drives better than any other old car I've had.
  15. OLLIN
    OLLIN
    that's my buddy Will's. Only 23 years old! heres how it looks now.
  16. Silhouettes 57
    Silhouettes 57
    Here is a Silhouettes member's '49 Pontiac called "The Ghost" down in
    Myrtle Beach, S.C. (looks like a '50 doesn't it?:D)
  17. TERPU
    TERPU
    That is a beautiful car. I also have a '51 but it's nowhere near that pretty.
    Tim
  18. Montechris
    Montechris
    No one upgraded to a dual master cylinder here?
  19. I have but made up a new pedal and bracket and mount the m/c on the firewall.
  20. Montechris
    Montechris
    I've been trying to research this on the HAMB, and i've not found too much information specific to pontiac so i started looking into the chevy swaps. The Chevy swap seems more complicated as the pedal is mounted on the master.
    The pedal on my pontiac is mounted to the frame, and the master is directly infront of it with a rod that simply pushes the master as you would expect. Seeing that this setup is much simpler than the chevy, i think i can just use a chevy truck master and hold it on with a bracket(in the same location as the original master) i can fab. Is the swap really this easy?
    Can i simply split the single feed brake line into two easy enough?
    Other questions i have are in regards to using a proportioning valve, and pedal/master pressure ratio.
    Any help is greatly appreciated.
    -Chris
  21. THE CHIEF
    THE CHIEF
    from MIAMI
  22. hsheartaches
    hsheartaches
    A '50 Pontiac clip. :D
  23. Montechris
    Montechris
    You all should check out www.1952pontiac.com its a great source of info for 49-54 pontiacs, and there is a forum which i see as a good place to discuss pontiac specific needs.
  24. edgeabilly
    edgeabilly
    I think 49- 53 Pontiac s are beautiful cars.:cool:
  25. Silhouettes 57
    Silhouettes 57
    Dug around and found a few old Pontiacs.
    The 55 might be a little to new???
  26. bab59
    bab59
    Ahhh Bump for inspiration.
  27. my girlfriends 50 silver streak , we're looking for the body side trim for it
  28. hogrider208
    hogrider208
    from idaho
    pics of mine
  29. Thanks for bringin this one back from the dead!
  30. [​IMG] this is how it looks now still looking for the side trim
