getting extra water capacity
Discussion in 'The Hokey Ass Message Board' started by pakkrat, Nov 27, 2008.
  1. You know, when we run these small grille shells, the water capacity is sometimes compromised. Have you did the trick of running heater hose in a loop all around the vehicle or some sort of piping and hose and maybe a heat sink to aid in cooling/volume? How'd it do?
  2. HemiRambler
    HemiRambler
    Nope, never tried that, but I noticed that adding oil capacity makes it take longer to get up to temp. On the same track you could also add an oil cooler as well.
  3. 29nash
    29nash
    from colorado
    what he said. Big oil cooler will help a lot.
  4. LowFat48
    LowFat48
    I`ve used something called waterwetter by redline products and it dropped the temp by 15-20 degrees
  5. jscoma47
    jscoma47
    +1 on the waterwetter works great every time.
