1955 Chevy truck Dropped Axle and disc brakes
Discussion in 'The Hokey Ass Message Board' started by bensimmons_05, Dec 2, 2008.
  1. bensimmons_05
    bensimmons_05
    from Weaver, AL
    Hey guys,
    I am new to the H.A.M.B. I wanted to post pictures of the drop axle I put together the other day. It seems when I was researching I could not find any good posts with pictures. So please comment and tell me if they helped. Ill post a couple at a time and explain what I was trying to show in the picture.
    The First was the test fit of the bracket on the old axle.
  2. bensimmons_05
    bensimmons_05
    from Weaver, AL
    This next Picture is the new king pin set up close and the difference between the dropped and old axle.
  3. bensimmons_05
    bensimmons_05
    from Weaver, AL
  4. bensimmons_05
    bensimmons_05
    from Weaver, AL
    Painted brackets and new (upgraded) tie rod ends.
  5. bensimmons_05
    bensimmons_05
    from Weaver, AL
    I painted the calipers to inhibit rust and the outside of the brake pads for the same reason and to give it a little extra. and here it is.
  6. coolerthanethan
    coolerthanethan
    from Miami, FL
    good thing you already flipped the tie rod with the modern ends to run under the springs, if you're taking any leafs off the spring pack to go lower keep in mind you'll have to shorten your pitman arm. my 54 has a 4" drop axle and 5 leafs removed from each side, i had to shorten the arm 4" along with also flipping the tie rod to underneath the springs
  7. bensimmons_05
    bensimmons_05
    from Weaver, AL
    Yea, I put it on the top to begin with and I could tell there would be interference, so I swapped it. I am also looking at the power steering conversion kit from CPP. That would eliminate the original pitman arm. I have a couple of my leafs removed (it was done already) but im not sure how many. How many do you have left on yours?
  8. Jivewire
    Jivewire
    from Indy
    Did you get the axle and disc brake conversion from the same place?
    This looks like it would be a good setup for my 58 Apache.
  9. KooDaddy
    KooDaddy
    from Wis.
    Welcome to the HAMB Great pics i'm doing a 57 GMC
    See you have 5 lug hubs did you convert if so what donor
    And where or who did you buy the drop axle and disc setup from ??
    Looking good
  10. bensimmons_05
    bensimmons_05
    from Weaver, AL
    I got the drop axle from a guy on ebay. His user name is stay-tooned. He accepts cores and that was a BIG deal for me. I ended up sending in two axles and that saved me $100 !!!!!! (prices may be different now) He also has a website, www.droppedaxles.com . He does good quality work and magna-fluxes the axles to test for cracks and is precise on measuring, really very thorough.
    The disc brakes derrived from a couple places. The conversion kit (consisting of the brackets, roller bearings, bearing adapters, nuts bolts etc.) came from cl***ic performance products (CPP) (www.cl***icperform.com) <- This site is heavenly. At the time the kit with the bearings was somewhere around $120! beat that! I work at autozone part time and this kit utilizes the brake parts from a 70-78 camaro. So the calipers, brake pads, caliper bolts. etc. all came from there.
    Oh yeah the tie rod ends and the original king pin set came from CPP
  11. Jivewire
    Jivewire
    from Indy
    Thanks for the info. Got any pics of your truck?
  12. bensimmons_05
    bensimmons_05
    from Weaver, AL
    Well this axle is actually the beginning of a whole build for the truck. The truck itself is actually nothing to look at at all right now. I bough a 55 with a wrecked rear end and bent frame and a 58 GMC with a good cab and frame. I will mate the two together to get a 55 chevy looking truck with a GMC cab. I built a rear end also. Now I am fixing to take the 58 to peices and blast the frame to put a c-notch in the rear and install all this good stuff.
  13. Wheelie
    Wheelie
    from Dallas
    Thanks for the links and info. $300 to drop my axle is pretty good. Save $100 or more. What was freight to and from to this dude?
