whats the best abrassive for blasting cast aluminum intakes?
Discussion in 'The Hokey Ass Message Board' started by JP55, Aug 8, 2004.
  1. JP55
    JP55
    from Salinas
    does anyone know what to use to blast an intake with? sand is to damaging. also any home fab tips on making 3 duece linkage?
  2. Roothawg
    Roothawg
  3. JP55
    JP55
    from Salinas
    will the glass beads work in a regular sand blasting cabinet? thanks for the info.
  4. tommy
    tommy
    [ QUOTE ]
    glass beads
    [/ QUOTE ]
    What he said. I get mine from an air compressor store and supply house. Cheaper than Tip or Eastwood.
  5. Yeah, they work in a standard cabinet if you can fit the intake in there ok. A pontiac intake is kinda big to fit into my kid's cabinet and I missed a few spots I couldn't reach...observe
  6. carkiller
    carkiller
    I use glass beads I buy from Harbor freight.
  7. JP55
    JP55
    from Salinas
    i have access to a cabinet that would probably fit a large intake like a 455 or something. i can just change out the sand to glass beads then, huh? what about walnut shells?
  8. JimC
    JimC
    from W.C.,Mo.
    Affirmative-glass beads.
    Works in a regular blast cabinet, got mine from the HF guys.
  9. silent rick
    silent rick
    sorry jp, don't mean to hijack the post, but what pressure do you guys use with glass bead? my compressor will maintain 90-100 psi when i sandblast. won't that pulverize the bead?
  10. JP55
    JP55
    from Salinas
    no problem
