Paint over powder coating help
Discussion in 'The Hokey Ass Message Board' started by Oldmanolds, Oct 27, 2008.
  1. Oldmanolds
    Oldmanolds
    Is there a way to prep a powder coated frame for paint? I need to touch up some road scars and don't want to spend the $ for a new powder coat job for my frame.
  2. just sand it like anything else, scuff it for adhesion
  3. 40StudeDude
    40StudeDude
    What he said...
    R-
  4. temper_mental
    temper_mental
    from Texas
    In the past I have bought paint from my powder coater that you spray on worked very well.My 2 cents
  5. 37FABRICATION
    37FABRICATION
    We've had frames powdercoated which acts as a mild filler then had it painted over to match the vehicle. Makes for a good sealer on bare metal and does a good job of smoothing seems and welds.
  6. Already a bunch of good advice.
    Just to add to the confusion that last thing that I had that was powder coated was a pair of cal custom rocker covers.
    I couldn't get nuthin' to stick to 'em. I finally scuffed em and sparayed on a couple of coats of zinc chromate primer.
    Then I was able to paint 'em just fine.
  7. Whistlercowboy
    Whistlercowboy
    Get some MEK from HD (Paint section) or wherever and mix a small amount with the powder until you get a paste--dab it on the part and smooth it out.Perfect for the little touch ups.
  8. Streetwerkz
    Streetwerkz
    Sand and treat just like a high build primer, then paint on top like any thing else.
    they are both polyester base products, and compatible with each other.
    We Powder Coat car frames, body's ect all the time for a primer coat.
    We have guy's bondo over the powder also.
