XM radio from my ipod hook up?
Discussion in 'The Hokey Ass Message Board' started by daveyboy56, Dec 8, 2008.
  1. daveyboy56
    daveyboy56
    Ok i did the i pod hook up from the tex here on the hamb. It works good.
    But i won a xm radio set up at a xmas party and want to tie that in how do i do that? Any elec guys out there?
    Thanks Dave
  2. daveyboy56
    daveyboy56
    btt for the night guys from page 7
  3. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    are ipods traditional?
  4. daveyboy56
    daveyboy56
    its called xm xpress ez
  5. daveyboy56
    daveyboy56
    Oh and i dont have a radio only a Ipod
  6. how did you hook up your ipod? using an adapter cable to an amp? if so, this will be easy. check to see if your xm unit has any external outputs and get back to me...
  7. daveyboy56
    daveyboy56
    it has ant in / audio out/ and dc in that is all.
    i did the ipod hook up from tex files here on the hamb
    so i had to up in a ipodplug with rac cable to a volume control box rca cable back to a amp. and a 12 volt power
  8. Evel
    Evel
    Plug the cable that you used on your Ipod to the Audio Out on your XM and it should work
  9. daveyboy56
    daveyboy56
    it has a right and left rca out of the ipod/ and a small jack for the xm audio out
  10. simple...go to radio shack and get a 3.5 mm (standard headphone jack) cable to rca adapter cable. you can use "y" adapters to connect both ipod and headphone jack, or unplug ipod cable at the lc-1 volume control and just swap cables depending on which device you're using...too easy. lemme know if this helps!
