57 Kustom...
Discussion in 'The Hokey Ass Message Board' started by DelinquentDoll13, Aug 10, 2004.
  1. DelinquentDoll13
    DelinquentDoll13
    here's my plan for the car...
    shave the emblems, fin insert, scripts
    make(?) bubble skirts
    58 impala roof scoop, and maybe bumper
    56 lincoln steering wheel,56/57 lincoln hubcaps, 57 lincoln trunk emblem
    grill like a 53/54? kaiser, painted candy pink w/starburst floating in the center
    lowered w/ white walls
    paint like stuff watson did for barris.... white pearl with pink flake and gold outlines
    and those stars i mentioned in my intro here and there....
    so that's "the plan"...
    ~josie
  2. DelinquentDoll13
    DelinquentDoll13
  3. Anderson
    Anderson
    from your drawing....is it a 4 door??
  4. DelinquentDoll13
    DelinquentDoll13
    yeah... there cheaper [​IMG]
    to put on the skirts were gonna have to add apiece to the fenders so it works out right...
  5. I like yer plans for it ,espescially how you're doing the side trim.I've seen way too many 57's with "belair" side trim,and have allways felt they looked good with less,or none at all.
  6. KustomSkylark
    KustomSkylark
    from Sacramento
    What does the car currently look like?
  7. 40StudeDude
    40StudeDude
    [ QUOTE ]
    [/ QUOTE ]
    Huh? I've owned a ton of '57 Chevies and I've never had to add a piece to the fenders to make the skirts work...explanation pleeze.
    R-
    PS, the ideas look good, but I'm thinkin' you're gonna have a tuff time finding some of those parts...
  8. DelinquentDoll13
    DelinquentDoll13
    look at my intro....
  9. 40StudeDude
    40StudeDude
    [ QUOTE ]
    [/ QUOTE ]
    If you're talking to me Doll, wanna point me in the right direction? I'm still a bit confused from adding a piece to the '57's fenders.
    Can't you make it a little less like a treasure hunt?
    R-
  10. DelinquentDoll13
    DelinquentDoll13
    i want bubble skirts and if i juat put them on, either i cant open the back door, or there will be a little gap....
  11. DelinquentDoll13
    DelinquentDoll13
    what's the fun in that [​IMG]
  12. 40StudeDude
    40StudeDude
    [ QUOTE ]
    [/ QUOTE ]
    OK, call me dense but I get it now.
    When you stated you had to add a piece to the fenders, I ***umed you were adding a piece (of something) to the rear fenders of the car...somehow.
    What you should have said was that you need to add a piece of the fender skirt to the rear doors...and cut thru the skirt so you can open the door.. Is this correct?
    Man o man, it's hard on my ESP when I don't get things right the first time around.
    R-
  13. DelinquentDoll13
    DelinquentDoll13
    [ QUOTE ]
    [ add a piece of the fender skirt to the rear doors...and cut thru the skirt so you can open the door.. Is this correct?
    R-
    [/ QUOTE ]
    that wasn't my first idea, but that would work too...
    i was thinking more along the lines of just moving the skirts back a few inches to clear the door, then filling the little gap...
    ~josie
  14. 40StudeDude
    40StudeDude
    [/ QUOTE ] that wasn't my first idea, but that would work too...
    i was thinking more along the lines of just moving the skirts back a few inches to clear the door, then filling the little gap...~josie
    [/ QUOTE ]
    OK Josie, but from an artist's point of view (that'd be me!!!), that's gonna change the entire look of the rear...a fender skirt usually is centered over the wheel, save for a bubble skirt...and it looks better (IMHO) if it's forward of the wheel opening ...gives it a moving-while-standing-still look. If you cut off the wheel well by adding a section to it and moving the skirt back, the skirt will look like it's "slipping" toward the back of the car...from an eyeball perspective, it'd look odd...and might make changing a flat tire a problem.
    I think you're better off adding the bubble skirt to the car in it's normal mounting, and then cutting the door opening straight down...hiding the dog leg of the door. You'll have a minor problem trying to figure out how to attach the trimmed skirt piece to the door but since it'll be fiberglas it won't weigh a lot, and when painted to match the car, the door opening will go away.
    Is that your '57 in the pic with the trailer? Or have we seen the one you own yet?
    R-
  15. DelinquentDoll13
    DelinquentDoll13
    yeah... i think you may be right.... that's why i posted this to get ideas/advice....
    yep, that's my car...
  16. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
    <font color="green">Did you ever figure those stars out?
    Perhaps they never came on cars?
    Maybe they were on boats or some other oddball thing I can't think of.
    If you're wanting to run three of some sort of emblem, take a look at the emblems on the rear pillars of 60-61 Ford Starliners.
    I've always liked those.
    I bet they aren't cheap either.
    Anyway, start looking around at things other than cars for ideas.
    Old appliances had some pretty cool emblems on them.
    RASHY </font>
  17. 40StudeDude
    40StudeDude
    Have you checked Nite Prowlers in Missouri for those bubble skirts? Buying them would be easier than making them unless you know a good metal smith or someone good with 'glas. They may have that '58 roof scoop as well...
    The Lincoln wheel will have to have the center (column splines) cut out of it and a Chevy center tig-welded in to make the steering wheel work. The hubcaps are just a matter of finding them...so are the stars.
    The '58 bumper is flatter and a bit squarer than the '57's...and the bumper ends are smoother...the "bullets" that you've got stars in on your drawing is not on a stock '58 bumper, unless you're going to adapt the '57's "bullets" to the '58 bumper...Can't figure out what type of grill you're going for in your drawing, can you explain that one to me pleeze?
    R-
  18. DelinquentDoll13
    DelinquentDoll13
    i went to the barris site, and email 'em... just waiting now... i could make them out of some sort of resin.... i want to paint em gold flake anyway....
    ~josie
  19. DelinquentDoll13
    DelinquentDoll13
    i had no idea how to do the steering wheel, thanks... i want a rear 58 bumper. i like the licece plate piece on it. here's kinda what i want with the grill.....
  20. Gruizer54
    Gruizer54
    hey, I just moved to Livermore. Is the Rambler parked over on P street next to a 53 chevy? I drove by that dirt lot today. I know I've seen your 57 around town. Glad to see you made it to the HAMB.
  21. DelinquentDoll13
    DelinquentDoll13
    why yes indeed! that's my mom's place.... i'm over on palm ave....
  22. 40StudeDude
    40StudeDude
    [ QUOTE ]
    [/ QUOTE ]
    That'd work if you use the stock '57 end pieces...you'll have to cut the '58 bumper (narrow it) to fit between the stock end pieces and probably figure out some new bumper irons(hangers/brackets).
    Might be easier to build the grille out of aluminum if you plan on painting it...finding one of those will be next to impossible. Besides, that opening shape doesn't lend itself well to a '57 grille opening...not only that, but you've still got to figure out where to put park lites/turn signals.
    I ***umed you'd already found the "stars"...I figured they were '57 Lincoln...I think the Lincoln hubcaps have stars in them. Oh yeah, wait, '57/'58 Pontiacs used some type of star on the side of some models.
    R-
  23. DelinquentDoll13
    DelinquentDoll13
    there was one of those grills on ebay for $59, and it was broke... i figured the grill would just have to be made anyways.... on the 2nd pic, where the stars are on the front bumper ends, i want to put the turn signals behind them... the stars don't come off of any of those... the ones i want have 8 points.
  24. A 57 Buick grill fits right into the 57 Chevy opening without any modifications and looks the same as your drawing except it's convex rather than concave... looks real cool too. Question....where do you find one....dunno.
  25. DelinquentDoll13
    DelinquentDoll13
    i really want it to curve in.... and i want wider teeth than the buick grill....
    ~josie
  26. HotRodHon
    HotRodHon
    You have some good ideas. The grill in your picture is a kaiser grill. Came from the style that had the heart shaped windshield. I'm not sure from which year. I had one in a little 52 Chevy that was a knock off of the g****vine. It probably would be easier to make one then find a good one.
    Craig
  27. Zodoff
    Zodoff
    The star you want for your grill,can be found on lincoln premiere trunks lids. 57 models. (very similar). theres a keyhole in the center,but it could probably be covered with a little cone bullit.. also,its some smaller ones on the doorsides in them,maybe better to use. But you know that... [​IMG]
    Z
