who knows a lot about Woody Gilmore front engine dragsters?
Discussion in 'The Hokey Ass Message Board' started by Foul, Dec 9, 2008.
  1. Jeem
    Jeem
    Alliance Vendor
    There's certainly no shortage of great ideas for books. I'd buy this for sure.... dang man, can you imagine all the rolling ch***is shots and diagrams and insider stories.....That'd make a helluva great read!
  2. 32 Barn Car
    32 Barn Car
    from Oregon
    Found this last night in a mag I was reading , it's from Jan 1968 so info is probably mid-late 1967 ..........Z.D.
  3. Foul
    Foul
    Don said it's probably a Frankencar.
  4. I would sure like to buy an issue of that Drag Racing mag. PM if you have one.
  5. Daddyfink
    Daddyfink
    Well, if you are looking for something to just make p***es down the track with a mild engine in it and the price is right, then why not! But, if you are looking for a real deal Woody or a future Cackle Car, then you should really p***!
  6. 6-71
    6-71
    I dont know much about Woody Gilmore dragster ch***is,but I do know there is one hanging from the ceiling at the originalQuaker Steak and Lube in Sharon Pa. I have studied it several times while having wings and beer. If I recall the sign says it is from around 1961.It currently has a small block chevy with enderle injection on it. not that it makes any difference it may be Hilborn injection.:)
  7. Rick Sis
    Rick Sis
    from Tulsa OK
    This appears to have been originally built as a twin engine ch***is. It can get pretty difficult to determine the origin of something like this. The twin engine stuff from this era is often one off and also often built by the lesser known shops.
    We had one that was a twin engine ch***is from this era, and I don't remember ever finding out who built it, and never saw another anything like it.
    I think you may have better luck tracking previous owners than researching design.
  8. LIL RUSSIAN
    LIL RUSSIAN
    from midway usa
    I worked on a ch***is with many of the same features as this one, squared seat former bottom tube, ETC. I remember it as a davis car. Are the bottom rails trimmed with a long fillet cut to meet the top rail at the front torsion tube? Better pics would clear up some questions and help to identify it.
    Darrell Karst
    =D.K.ENTERPRISE=
    STREETRODS/HOTRODS & HARLEYS
  9. Foul
    Foul
    another email from Don; his experts say that it's probably, in part, a Joe Ito ch***is.
    dan
  10. LowA100
    LowA100
    I will try to check tonight. I have a Woody G 4 page sales brochure that shows a complete car minus drivetrain and back wheels set up for Hemi or Chevy. Price? $2,450!!!!
  11. In a post above, it was mentioned that Woody has a shop in San Raphael. Does anyone have an address or phone number?
    I'm going to the GNRS in January and would like to to a visit if possible.
  12. Rex Schimmer
    Rex Schimmer
    from Fulton, CA
    I used to hang out at Woody's shop in Lakewood back in the 60s and that is not a Woody car.
    Rex
  13. bushwacker 57
    bushwacker 57
    Rich you can give Lorry Azevedo at HAT RACING ENT 39 MILL ST SAN RAFAEL CALIF 94901 A CALL 1-415-457-1640 WOODY WORKS THERE.
  14. ardyboy
    ardyboy
    This ole car has a new home here in Canada. My son bought it and we'll hopefully be out with it this summer. I want to thank fellow Hamber, Dan Strohl for pointing us to the car. My son's pumped!!
  15. Hi ardyboy;
    Good luck with the new hot rod..Look forward to seeing the car out..
    1939fiat
    (Rick)
  16. Pyromaniac
    Pyromaniac
    from Nippomo
    I raced a 68 gilmore car that we updated known as the Valvoline Mean Lean and Clean Dragster. We ran that car to six national records and one championship nostaligia racing before moving on to jet dragsters in 1998. There are some great things about gillmore ch***is, and some bad things about old pipe that you might should be aware of, like old pipe can and will break close to the engine mounts with heavy big blocks. Needless to say with draglink steering, (all gillmore cars had draglink steering) if you break the top or bottom framerails, the flex steers the car instead of your ****erflys. Ours crossed the centerline at sacramento in 93 over this issue at over 150 mph at 3/4 track... dont let that happen to you, it plays hell with your confidance. Gillmore cars are VERY flexible and move on the track a lot as a result, although yours is so short it may not. Suggestion, strip to ch***is to bare metal (leaving the NHRA instpection and license tag intact to ***ist in your next certification) and inspect the tubes and welds closely even resorting to a ring magnaflux inspection if you find su****ious areas. The nhra obviously has and will sonic test it for wall thickness, additional supports will be required to keep it legal to modern specs especially in the drivers box area. Finally dont forget that you set your huevos right on the pumpkin, dont even think about skimping on the axles, ring and pinion and rear bearings. If you have not replaced these parts already, at least mag them and make sure they are pefect (ring and pinion and axles), make sure your carrier is solid and closed not welded spider gears. Lets not mince words, front engine dragsters are *****in and totally a drivers car (everything is in your face and between your legs) but if you skip or skimp on the details in the drivetrain or ch***is, they are deadly. Feel Free to contact me at oldschoolcars1@yahoo.com with additional questions or whatever. Have a blast!! I wish I was young enough to be building my first dragster again!!! We did successfully campaign our car for 8 years in the 90's, so we know it can be done!
    My Best...Michael, Pyromaniac Racing Jet Team
  17. reidbear
    reidbear
    Here are some more detailed photos of the car for those of you who are still interested in identifying it. I appreciate all the help. The guy i bought the car from added that he was told from the previous owner the ch***is was cut from behind the rearend completely off and updated. I think this car has been modified and updated so many times i'll never really know its origins.
    Thanks again, see you at the track.
    Aaron
  18. reidbear
    reidbear
    more shots
  19. reidbear
    reidbear
    last one
  20. Foul
    Foul
    I hope you were able to get the body panels with it?
    dan
  21. reidbear
    reidbear
    yes sir and i hope i never have to take the left hand panel in front of the engine off while i'm at the track. seems that the pitman arm will have to come off to take the panel off without killing the paint.
  22. reidbear
    reidbear
    *in front of the tire
  23. crg12421
    crg12421
    Yes I do know a few things about Woody cars....He is my father-in-law and lives with me. Let me know what your questions are and I can ask him directly for you. He is not a computer type person and does not type. my e-mail is acelr8r@aol.com
