Comments on stance
Discussion in 'The Hokey Ass Message Board' started by Poltax, Dec 10, 2008.
  1. Poltax
    Poltax
    from UT
    Just picked up this 58 Chevy truck. It has a 396 in it with auto trans. Looking for thoughts on chop (3-6"), and also the stance.......yikes.......be kind.
  2. VonDust
    VonDust
    A good general idea for stance would be to keep the same amount of space between the lip of the wheel, and the bottom lip of the fenders all the way around. Grant it, that's not the case for all vehicles, but in your case it applies.
    My dad has a '57 chevy truck that's on the ground, but it has a nova clip under it. I'll try to s****e up a pic for ya.
  3. Little Wing
    Little Wing
    from Northeast
    Chop 3 at most and lower to stock level ,,least get that *** end down,,Nice looking truck
    Just lower the rear will make a world of difference
  4. JohnJoyo
    JohnJoyo
    Alliance Vendor
    from Austin, TX
    I wouldn't chop it if I were you. If you absolutely have to chop it....only a little bit. Lower it first and dial in your stance before you go chopping it.
  5. Definately lower it first.
    Then look at how much needs to come out,
    I would say that a couple of inches might be it,
    but untill you drop it it's hard to be sure.
    depends on how much you can drop the thing.
  6. Make sure you can come up with a windsheild that's going to fit before chopping, would be my only caveat.
  7. mercurial
    mercurial
    Just drop it. See my avatar on how it could look (albeit mines an F100 but you get the gist) or look on the thread 'My sh**tty old shop truck gets a small makeover' and see the killer stance flamedabone has achieved (Sorry Ford truck again!)
    I would leave the chop until the last resort IMHO.
  8. Muttley
    Muttley
    Some cars/trucks look retarded chopped and thats one of them. Lower it and drive.
  9. 32SEDAN
    32SEDAN
    Chopping a truck like that will really limit your ****pit space. However, if you're 5 feet tall, you should not have any problems... :)
  10. Old-Soul
    Old-Soul
    The man has a way with words!
  11. Drop it first. Maybe flip the rear axle for a quick 5". Might have to "C" notch it. Look like a nice truck.
  12. Poltax
    Poltax
    from UT
    Thanks for all the replies. I had the same thoughts on the height.
  13. Rick Sis
    Rick Sis
    from Tulsa OK
    That's a really nice lookin' 58. I'm wondering what the story is on why it's sitting so far up in the clouds.
    It may be a good idea to check with the aviation groups about the best way to get it safely back down to Mother Earth. Also, you may be required to file an IFR flight plan to drive it on a cloudy day.:D
    Seriously, correct the stance without going fad low. Straighten anything that's rough, invest in wheels and tires, chrome bumper, etc. and forget about the chop.
  14. Toast
    Toast
    from Jenks, OK
    Nice truck, Wheels and tires an drop it, a bunch! IMOP
  15. mad torquer
    mad torquer
    This was mine. G-body front stub. 5" bridge and axle flipped. Ran and drove great. You can probably get away with a c-notch if you don't want to go too low.
  16. JLasvegas
    JLasvegas
    from Skin city
    Drop it and throw some different wheels and tires on it and be done
    post a pic of it in the photoshop thread and im sure someone will do some magic to it to show you how it will look
    PS Mad, that truck is the balls
  17. SquigMachine
    SquigMachine
    NO CHOPPY!!!! lower it yes then make the 396ci a hand grenade an run it
    (my 57' is runnin a 396/TH400 setup to) im not going to do anything to the body but drop it alittle and find some Crager SS
  18. BrandonB
    BrandonB
    from nor cal
    Exactly. The stance on a truck like that is everything.
  19. daddio211
    daddio211
    Agreed... BIG drop, NO chop. It's your truck though so do whatcha want. Just be aware that this is supposed to be one of the more difficult trucks to chop, so don't try it at home. Get someone reputable with experience chopping this cab or you could end up with a worthless butchered truck.
    Welcome from down in St. George!
  20. slammed
    slammed
    If a chop were to happen it would be 1.5-2" max, then pancake the roof to help the profile it's a ton of work. Lower it 1st. Good, soild looking truck. The baby rat motor is cool.
