The Low Buck Bagged Binder
Discussion in 'The Hokey Ass Message Board' started by C4 Metal Werks, Jun 30, 2008.
  1. C4 Metal Werks
    C4 Metal Werks
    Got the pedals and steering column mounted. Still not sure what I want to do for pedals.
  2. C4 Metal Werks
    C4 Metal Werks
  3. the machine
    the machine
    C4, I like that pedal ***embly, binder is looking good, that cab is in great shape, nice work.
  4. C4 Metal Werks
    C4 Metal Werks
    Thanks. Yours was part of my inspiration.
  5. Solidaxel
    Solidaxel
    Three pedels and a Turbo350, what did I miss ?
    I have that #870 327 in my 62 Vette and it works very very good!
    Upgrade the cam and you will realy like that 327!!
  6. C4 Metal Werks
    C4 Metal Werks
    Originally I was going to run the TH350. Now it is coming out and a T5 is going in. Thanks for the 327 tip.
  7. C4 Metal Werks
    C4 Metal Werks
    Gusseted the rear frame,
    Steering column firewall bearing mount inside,
    outside,
    Originally the backside of the front fenders was an inch of the ground,
    now I have about 6"
    Steering wheel installed,
  8. C4 Metal Werks
    C4 Metal Werks
    Stripped the paint off of the cab. Between Jasco and 3M C.R.U.D. pads on the angle grinder it work well.
    Shortened the bed 10" and cut the floor out.
    Hanging the fenders off the back of the bed and I'll build a roll pan to go between them for the tail lights, exhaust and licence plate mount.
  9. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    looks good.
    One question: why right hand drive?
  10. hotdamn
    hotdamn
    this might make me a ****, and only a few of you other ****s out there will know what I am saying, but are those BRM's?
    didn't know you could do that:)
  11. C4 Metal Werks
    C4 Metal Werks
    They are BRM's:) I still might go with them.
  12. Nice,,, but I dont like the single shear on the rod end on the brake plunger. One hard panic stop could shear that grade five right off. You have the room and the skills to make that safer.
  13. C4 Metal Werks
    C4 Metal Werks
    I don't think it is even grade 5. I used a piece of all-thread to get my length correct. I will use a grade 8 or better bolt for the final install unless you suggest something better.
  14. hotdamn
    hotdamn
    haha:)
    **** it put some sprint stars on it!
  15. C4 Metal Werks
    C4 Metal Werks
  16. C4 Metal Werks
    C4 Metal Werks
    The wife stripping
    the tailgate. Spent a couple of hours straightening it out then removed most of the paint.
    Got the rear fenders ready to mount and rear tires today.
  17. NortonG
    NortonG
  18. Model A Mark
    Model A Mark
    from dallas
    that work looks realy good to me, lots of thinking,
    mad skills 4sure ......
  19. wakeboarder311
    wakeboarder311
    from ohio
    what are those 20" steel rims?
  20. C4 Metal Werks
    C4 Metal Werks
    Late model Dodge truck.
  21. JLasvegas
    JLasvegas
    from Skin city
    I bet she would rather be working on that Wagonaire huh lol
  22. 55 dude
    55 dude
    get her a respirator as those chemicals do bad **** to your lungs.
  23. C4 Metal Werks
    C4 Metal Werks
    Ya, but the sooner the truck is done we will have room for the Stude in the shop.
  24. C4 Metal Werks
    C4 Metal Werks
    Got my air tank today for my air bag set up. Not sure what it is out of
    but it's about 5 gallons and was hooked to a compressor as an
    air storage tank.
    It only has 2 ports so I was going to run a copper or
    stainless line to one of these vintage fuel logs so I would have a few more.
    or
    This will all be mounted in the bed and I'll have a vintage looking set up.
  25. The Law
    The Law
    from N. AZ
    That is an oxygen tank from a WWII era aircraft. They used a lot of them in the B-17's. Awesome find, try not to cut it up!
  26. C4 Metal Werks
    C4 Metal Werks
    Notched the bed for the rear axle and modified the 40 ford rear fenders to fit flat against the IH bed.
  27. PUTRID FAME
    PUTRID FAME
  28. fab32
    fab32
    Keep the updates coming.
    Frank
  29. studeboy
    studeboy
    I like how this build is shaping up. Be interested to see how the narrowness (is that even a word :) ) of the front suspension is addressed. The front wheels look to be about 7-8 inches inside the fender lip.
    Eric
  30. Wicked50
    Wicked50
    truck is coming along keep up the good work
