Holesaw lube for cutting aluminum, wax or oil?
Discussion in 'The Hokey Ass Message Board' started by Black Primer, Dec 13, 2008.
  1. cruzingratiot
    cruzingratiot
    from Detroit MI
    I have Always used WD-40
    iwas a machanist for 20 years
    all the other cra# my boss bought never worked as good
    Paul Jug
  2. art.resi
    art.resi
    Liquid detergent and water rinse.
  3. HemiRambler
    HemiRambler
    If you need ear protection while you're holesawing aluminum - you're running it WAY TOO FAST!!! When in DOUBT - run it as slow as you can - nothing will kill your holesaw faster than overheating it.
    I never tried the windex idea - but I will the next time.
    The thing you may want to consider is to drill a couple relief holes in your part. A relief being a small hole that is about tangent to your "slug". It will allow a path for the chips to escape when the teeth become buried in your part. It won't take but a minute to do and will make the holesawing go much easier.
  4. lehr
    lehr
    Bar soap works good it's easy to clean and smells fresh !
  5. bobscogin
    bobscogin
    Ding-ding-ding! We got a winner!
    Bob
  6. I use this trick too.
  7. Magnus
    Magnus
    from Sweden
    Kerosene works fine.
  8. JOECOOL
    JOECOOL
    I just get the fat girl from next door to rub all over the part,leaves enough graease for great cutting.Also highly exciting if your an old guy like me.
  9. WZ JUNK
    WZ JUNK
    from Neosho, MO
    I drill a 1/4 " pilot hole. Then use a hole saw with a straight 1/4 " rod instead of a bit. This keeps the center hole from enlarging due to the drill eating away at the center hole as you use the hole saw. It keeps the hole saw true and make a more accurate hole.
    John
